Thanks. May I ask where you found this info? I searched high and low and couldn’t find the spec. I was on the verge of emailing SVS support.The SVS input sensitivity is about 350 mV at full gain. The M33 is not the problem![]()
I reached out to SVS and they confirmed the following which sounds like it will work well with the M33:
The problem is in the quality of sub outs.I’d like to know if the low output voltage of the M33 is sufficient to reach maximum output on the SVS. Unfortunately I can’t find any input sensitivity information on the SVS.
Like I was repeating many times: NAD priorities a weird. They are cutting the costs where they should not. Many far less expensive Chinese devices which have been subject of the reviews here contain better parts, both active and passive ones. Hats off only to Purify module.The new M66 uses the same type of DAC for the subs.
I would also have liked to see the measurements in bridge-mode setting, as you can definitely hear a difference.A bit dissapointed actually...
Cheap low performance DAC. You can easily find the tech sheet on the web.And what is explicitly wrong with the sub out?
Btw. You do not connect dac output with computer ribbon cable to the Purifi module...Btw. the Purifi modules built under license are of higher quality, otherwise a bridge-mode operation would be Russian roulette![]()
I am always just listening. The skillful engineer is doing the rest what I prefer to be done. Why ES9028QM plus I/V converter opamp has not been engaged for sub out? That is the question.You shouldn't be so fixated on measurements of individual components. The interaction must fit![]()
Sorry, with all due respect but this is the border which I am not crossing over.And which of these 'issues' now has an audible impact?
