Michael YYZ
I should’ve posted this here:
https://www.audiosciencereview.com/...er-amplifier-review.15939/page-10#post-513942
@amirm
out of curiosity, did you identify the large silver rectangle up the rca plug? Looks like a shield. Transformer?
right, make sense.That should be the relay which switches the input between balanced and single ended.
Sure. I tried to find an email address but it was hard. I finally found a support line and sent them a message. Hopefully it gets to the right person and they respond.
Maybe in the past they had some deal with nad that was Licence/Royalty based because of mention that Nad where making slightly modify ones, but this here looks like the modules themselves. Unless something is special with Nad, Hypex/Purifi had and have, as far as I know an OEM business model. They shouldn't get royalties, You buy the number of modules you need and they are yours to use. That said I won't pretend I know the exact deal behind, but generally that's how they operate. Maybe Purifi isn't exactly like Hypex neither.While extracting a pretty penny in royalties from NAD who are forced to use their lunch money to pay for their caps.
I find a clearer picture on the internet, and it's rated 1200W, I would still like to know how they calculate this, but I never ran into a problem following these. So basically, a dedicated circuit, maybe, but it wouldn't be unsafe or problematic to add things on the same circuit that don't pull more than 240 extra Watts, unless you are running the same test as Amir for minutes.
That 80% rule is for a continuous load. So for me when I charge my EV I can only pull 40A on my 50A 240VAC circuit. I think you can make the argument that this device doesn't present a continuous load.
That's the reason that most "1500W" hair dryers in the US actually only draw 1200W.
@amirm Give it a go. Do you feel lucky? (I would totally do it, each amp has comprehensive protection. I wonder what two Purifis bridged would hit into 8/4R?)
We did this with the M22.Based on this amplifier's design, you could just for fun (and if you were brave) use the already opposite polarity channels, drive them with a common signal (Y splitter)
Exactly, and even a top end pc don’t cost that muchIt always saddens me to see low quality caps. You would expect a product like this would be built with durability in mind. When I see PC PSU's it is always 100-105C caps in there.
It's interesting they decided to use Lelon brand low cost capacitors in a $5000 amplifier instead of spending a few more $ and get Nichicon or some other respected Japanese brand of capacitors. Especially considering it's a switchmode power supply with high ripple current where the capacitors get quite a workout.
Well, a 1600W Corsair PSU is like €500-600. But you do get quality:Exactly, and even a top end pc don’t cost that much
https://www.corsair.com/eu/en/ax1600i-psu said:With higher end components like GaN transistors and 100% 105C rated Japanese capacitors, as well as the FDB fan, you'll be able to rely on the AX1600i for your builds for years to come. And our 10 year warranty gives you peace of mind.
Note: I'm just some engineer who now makes software that rewired his whole 1925 house a few years ago. So, take this with a big ole grain of salt since I am not an electrician or NEC expert.
The NEC has an '80%' rule, though I don't know how strict it is, or if it would even apply here.
https://www.electriciantalk.com/f2/80-rule-67638/
I think the general idea is that you can use up to 80% of the circuit/breaker in practice e.g. 15 amp breaker/circuit can use 1,440 watts (15*120*0.8).
In your 5 channels load test in the original review you were drawing around 1,455 watts (262*5/0.9, assuming 90% efficiency)!
The purpose of the 80% rule seems to be for long term continuous loads, like hours. So it's unlikely to cause an issue here,you can likely get more out of this unit than that in practice. It does make me think that a dedicated circuit would be a good idea.
