You would never in a million years hear the difference and this design has substantially more power and much higher level constructionNAD needs to learn from designers from topping. Not worth the money for that level of sinad.
Adam, are you saying Google is your friend?Surely all that information is provided on the NAD Web site. Do we really need to add work to Amir’s plate for providing information that is readily available elsewhere?
Someone had to say it!![]()
Be interesting to see if they do. Certainly I'd forgo the fancy case to save a grand and a half.Agreed, except for price which has been subjected to a huge markup for pretty cosmetics and the “Master Series” name. Knowing NAD, they will release an almost-identical version of the amp in a plainer box and charge half the price in their regular “black box” series.
My guess is that they want their statement trophy product to measure as SOTA as can be. Any pot will hurt channel balance and noise a bit. Whether it matters, is really up to any. They probably also expect you to buy their matching Pre.Cool excellenthowever the lower tier c298 actually has variable input sensitivity.
Amp should at least have some gain settings imho , this totl product omits that feature ?
Hopefully the pre actually matchMy guess is that they want their statement trophy product to measure as SOTA as can be. Any pot will hurt channel balance and noise a bit. Whether it matters, is really up to any. They probably also expect you to buy their matching Pre.
I'm trying to sell an almost brand new Hypex Nilai500 with no luck. The resale value for those class D amp is pretty bad. Maybe a Nad with brand name recognition will give a bit more of it, but I wouldn't expect much.And it probably and hopefully will have much longer and better parts support and service, plus it won't have a newer and "better" successor every half year making it losing its re-sale value drastically.
Sorry I am not sure what you mean by "not unknown to have too much gain everywhere"?Hopefully the pre actually matchit’s not unknown to have to much gain everywhere ?
It's comments like this that people on other forums zero in on when slagging ASR and its members.NAD needs to learn from designers from topping. Not worth the money for that level of sinad.
Because SINAD of an amp does not matter, if it doesn't have enough power. The highest priority challenge in class D design is to maximize efficiency and power while making class D amps capable of driving very low impedance loads. Max power output should not be sacrificed for the distortion that you won't hear. Purifi is providing great class D solutions to the market and If Topping can make a 1000W into 1 ohm amp with 110db SINAD (which 1ET7040A is capable of) we can rejoice that too.So what’s the point of rejoicing when toppings dacs are having 120db. In 2023, everything should have 120db min as a standard
Also, because once you get over 95-100 SINAD in an amp, you're well beyond "audible difference" territory and into "engineering bragging rights" territory. You're WAY better off with an amp that has a SINAD of 101 that has the features, power output, and build quality you need, rather than an amp with 120dB SINAD that doesn't meet your needs in other respects.Because SINAD of an amp does not matter, if it doesn't have enough power. The highest priority challenge in class D design is to maximize efficiency and power while making class D amps capable of driving very low impedance loads. Max power output should not be sacrificed for the distortion that you won't hear. Purifi is providing great class D solutions to the market and If Topping can make a 1000W into 1 ohm amp with 110db SINAD (which 1ET7040A is capable of) we can rejoice that too.
Btw Purifi is going to launch 1ET9040BA which is going to be capable of pushing 1500W into 2 ohms.
Dunno. I sold my M28 with ease. Keeping my C298s.I'm trying to sell an almost brand new Hypex Nilai500 with no luck. The resale value for those class D amp is pretty bad. Maybe a Nad with brand name recognition will give a bit more of it, but I wouldn't expect much.
The M23 does have a 3-position gain switch. Stereo mode: 19dB (low), 23.9dB (mid), 29.2 (high).Cool excellenthowever the lower tier c298 actually has variable input sensitivity.
Sure, recognized hifi brands sell well and Masters series goes into "I want one... but cheaper" category for many. No problem at all.I'm trying to sell an almost brand new Hypex Nilai500 with no luck. The resale value for those class D amp is pretty bad. Maybe a Nad with brand name recognition will give a bit more of it, but I wouldn't expect much.
They made excellent job with their power supply.So far our tests have been with resistive loads of 4 and 8 ohm. Let's add reactive (capacitive/inductive) load into the equation including going down to 2 ohms:
Ah, my bad for missing that....The M23 does have a 3-position gain switch. Stereo mode: 19dB (low), 23.9dB (mid), 29.2 (high).
Or not. I have been very unhappy with the service support from NAD re: my T758v3 AVR. I certainly would not weigh NAD's brand equity as a point in their favor at this point.And it probably and hopefully will have much longer and better parts support and service, plus it won't have a newer and "better" successor every half year making it losing its re-sale value drastically.
Based on the picture in your 1st post. Looks like gain is set to High. Is that the gain used in tests?Ah, my bad for missing that....
