pogo
- Joined
- Sep 4, 2020
- Messages
- 2,617
- Likes
- 1,012
And does that result in an audibly better result? The link you provided doesn't provide any way to compare/verify.Better PSU, bridge mode, matched purifi modules, dynamic output power (see also here: Link), ...
NAD does not use any off-the-shelf purifi modules, but rather modules produced and matched 'in-house'. Matched modules are necessary for the bridge mode to work properly!
Power. I'm not very interested in amp sinad but proper PSU and short term power handling is always audible when it is needed. If you run out of juice you're out of luck because nothing can substitute that. It's an amplifier after all.Better in what way?
Yes, bridged mode gives more power, indeed.Yes, see also here: Link
Most of us are more than likely using powered subs. I don't know anyone personally who has unpowered subs.amper42
1. 8 watts an hour (70,080 watts a year IF YOU LEAVE IT ON 24/7 [which I think very few do]) kills your power budget while saving the world (times the people who actually buy THIS particular piece of stereo gear AND LEAVE IT ON 24/7) Uh-huh.
2. 10 watts won't get many peoples subs going (mine are custom built by me & are passive 2 OHM and have their own amps).
And for normal listening I am definitely using at least 2 X 10 on the subs (which would have at least 200 watt peaks on the subs alone.
3 What you prefer has nothing to do with anyone but you.
I prefer one AMP per main speaker and one AMP per sub.
I don't know anyone else that prefers what I prefer but I do know people who run three amps or more in their system.
I'm the other way around, maybe because I am involved in a "maker" community.Most of us are more than likely using powered subs. I don't know anyone personally who has unpowered subs.
My comment is based on the review we're posting under.3. I would prefer standard Purifi modules built by Purifi rather than circuit boards built with a 3rd party licensing agreement that allows deviation from the original design.
It's really hard to argue with a straight face that a 3rd party licensed Purifi product is superior to OEM Purifi modules. It would require a lot of testing to even consider that statement is NOT make believe.
Lumin T2 or Lumin D3 maybe, still lookingIt depends on what you have in mind. If you want to use the bridge-mode in conjunction with an M33, you have to use the M23.
Just purchase an open box or demo or customer return for 25% less and it’s totally clutch. Just make sure that it has warranty. If it’s an authorized NAD retailer most likely it is. To be beyond certain message them directly and ask.Is it worth the extra cash to get this instead of the C 298?
Thanks for the great adviceJust purchase an open box or demo or customer return for 25% less and it’s totally clutch. Just make sure that it has warranty. If it’s an authorized NAD retailer most likely it is. To be beyond certain message them directly and ask.
If you’re interested in more details just dm me.
I really enjoy the M23, and my opinion is biased because I got little time with the c298. I get flack for my comments on class D, and I’m not looking to debate that as it is purely objective, but it’s my favorite amp. So much so that I purchased two. I really don’t like to spend that much money but I was definitely compelled to do so.
The M23 uses Purifi Eigentakt modules. What advantage is the M23 vs a VTV Eigentakt amp and a Topping Pre90 preamp for less than half the price?
They dont use the actual Purifi module, NAD builds their own to Purifi specs using their own partsSupremacy in sighted listening tests![]()
