NAD M23 Stereo Amplifier Review
Rate this amplifier:
    Votes: 2 0.5%
    Votes: 13 3.5%
    Votes: 108 29.3%
    Votes: 246 66.7%
PWM in class D is not a copy of original analog signal, it's essentially newly generated digital PWM signal (zeros and ones) modulated with source analog signal, the modulated PWM signal is then amplified. The problem is extracting the original analogue signal without distortion is nearly impossible, hence class D remains a niche amplification technology mostly for subwoofer use.
I wonder is Hypex a derivative from hype?
Ok, so you confirmed both that you are ignorant and that you are an anti-class-D troll (maybe because you think it is digital, and are one of those luddites who don't understand digital technology).
An analog signal is also not a perfect reproduction. It is an approximation of the original acoustical signal that is converted into a newly generated voltage, optical signal, or in worst case a mechanical approximation. Extracting the original signal without distortion is impossible.
Just because something is zeros and ones doesn't mean it is digital. You might be confusing it with binary. Digital means representing a signal by regular samples of discrete numerical values - the term "digital" comes from "digits" - numbers, and originally "finger", as in "counting on fingers". The french term for digital, "numerique", describes it even better.
Hypex and purifi use analog PWM. As I explained, they can vary the pulse width continuously, without any discrete steps or quanta.
You also still seem to confuse limited bandwidth with distortion.
I wonder is Hypex a derivative from hype? I think hype is really the only way to sell this technology to "audiophiles" for multi thousand $.
So your point is a class A is "better" at maintaining the visual of a *digital signal* (because that's what a square is in most people's mind, even though in practice it never is)?
That is bizarre. Fundamentals aside (nope, no Class A amp nor anything else will ever present a perfect square, it's basic physics), the fact is:
1. Digital signals are very resilient. They do NOT have to be perfect 1 and 0 at all. That is the key advantage of digital - signal integrity is not required to maintain data integrity. A 0.92, a 1.03 etc etc are all perfectly valid 1s. No one cares about a perfect square signal anywhere.
2. Rest assured that when you listen to music there will not be a single square signal anywhere, so it is a silly moot point that doesn't prove anything about the fidelity in the "analog domain" you seem overconcerned about.
Basically, you are using a completely irrelevant proof point to make a weird argument. It's like saying a car is better than another because it drives a bit smoother when you put square-shaped wheels on it... it's like "why on earth would you do that, and wtf do u think it matters?"
Learn a bit about Fourier transformations, which are at the core of Nyquist-Shannon. Hint: it's based on sinus waves, can't get more analog than a sinus wave. One last time: math doesn't lie. Nor does it care about personal interpretations. Sometimes the problem in showing measurements to the uneducated is that they have zero clue how to understand the result. I challenge @anarchist to show us where John Atkinson says anywhere that the square signal result was in any way disappointing, or that he expects a perfect square to pop out on the output side to recommend a product...
You seem confused.
Just as a continuously varying voltage can encode an analogue signal, so can a continuously varying pulse width. So could also a continuously varying light intensity, or continuously varying current, or continuously varying frequency (that is what FM radio is). Any property you can vary can be used to encode an analogue signal. Hey what about a continuously varying groove depth in vinyl. That's another way.
All are just ways of being an "analogue" of the sound wave (see how that works?) - which is a continuously varying pressure wave. None of them are any more analogue than another.
You really need to learn some stuff about how things work before coming here to troll. You are just showing your ignorance, and are going to get schooled.
This post reminds me of the anti-class D propaganda on the SuperBestAudioFriends Web Site.
SBAF is basically a Schiit Audio fan boy site. I have nothing against Shiit Audio since I own a couple of their products. But the regular members at SBAF will attack any post that is positive on Class D or critical of a Schiit product. I know this from experience.
At this point it is pretty clear we are being trolled. :) My suitably-dumbed-down educational goodwill is exhausted. Let this person buy a 200lbs, $40k class A amp and enjoy the superior "sound quality". :-D Square signals and audio performance... what a sad joke if someone really believed it. Try testing speakers with full load like that while you're at it... :)
I have one of the latest generation Hypex amps. I have not heard a better sounding amplifier regardless of class. Obviously you have never listened to a quality class D amp from Hypex or Purifi; or if you have, your biases were fully engaged at the time. Please disparage elsewhere.
I was just playing with the idea to demonstrate the effect on a square wave of different frequency responses.
So I gave it a try.
Looking at 2 amplifiers:
Benchmark AHB2
Frequency response, from Amir's review
If I see correctly, that's behaving like a 1st order low pass filter at around 200kHz.
Let's say it's a Butterworth 1st order filter.
What would a 10kHz square wave look like ?
Cool.
Now, let's try with the NAD M23, or C298, or whatever amp using the Purifi module.
NAD M23
Frequency response, as per Amir's measurements above
NAD M23 Stereo Amplifier Class D balanced XLR frequency response Measurement.png
That's a steeper response.
Purifi's datasheet says -3dB at 60kHz and -6dB at 75kHz.
So let's try with a Butterworth 2nd order filter at 60kHz
Square wave at 10kHz would look like
That's different, indeed.
Does it matter ?
Now let's introduce another parameter:
Human hearing
What happens after our ear's own low pass filter is applied ?
That's a very steep low-pass filter, since some may hear at, say, 16kHz, but at 32kHz, for sure, we don't hear anything.
Meaning 0. Nada. -100dB or so at least.
Let's try and apply such a filter on top of the amp filter.
Here is what we'd get as a result.
Benchmark AHB2
NAD M23
In both cases, we get a pure 10kHz sine wave.
Of course, since 3rd harmonic and above are completely inaudible to any human.
(And the theory -and practice- tells us that a square wave may be reproduced by an infinite sum of sine waves at odd multiples of the fundamental frequency, with level decreasing as 1/order)
So are those differences in 10kHz square wave any relevant ?
Not at all.
By the way, don't say a Purifi amp can't do any square wave correctly.
Here is one (predicted) for NAD M23 :
Well, granted, that one is at 1kHz.
So at 60kHz, we already have 30 harmonics (including the fundamental), which allows a pretty accurate reproduction of the square wave.
OK, I had fun :)
Now let me grab a beer... :cool:
So I gave it a try.
Benchmark AHB2
Cool.
NAD M23
Does it matter ?
Human hearing
Benchmark AHB2
NAD M23
Not at all.
By the way, don't say a Purif amp can't do any square wave correctly.
OK, I had fun :)
Nice work - bookmarked.
So you saying the distorted output signal in the stereophile review is just our imagination?
It's not really about what can you hear at this point, we cannot hear THD below 0.05% levels, and our speakers distort signal to at least 0.5%, yet we say here that SINAD 90 is superior to SINAD 70?
The point here is that top of the line class D amplifiers are not able to amplify square wave without distortion, and A or AB class amps can.
Try playing back a square wave with a class A/B amp from a subwoofer and try to explain why it's "heavily" "distorted" even when using class A.
So I gave it a try.
Benchmark AHB2
Cool.
NAD M23
Does it matter ?
Human hearing
Benchmark AHB2
NAD M23
Not at all.
OK, I had fun :)
Interesting, I see that our friend @anarchist owns a Yamaha RX-3080 which is reviewed here: it appears to have bandwidth closer to the M23 than the Benchmark, so presumably would produce a square wave that is also closer to the M23?
This is about the available harmonics, not the class of amp so much.
Will there be any audible upgrade over Topping LA90 for Kef R3s in 3x5m room?
At 86db, the KEFs aren’t too efficient. Having the extra power might make a difference, depending on what you listen to and what levels. Borrow a Purifi amp and try (maybe there is an ASR member nearby who would be willing to help - I could, if you were on the UWS of Manhattan).
But remember that doubling the power only gives you 3 dB more sound pressure.
But the Topping LA90 = 56 W @ 4 ohm and NAD M23 = 361 W @ 4 ohm. That's 6x the power.
Poor Kefs will let the smoke out before taking anything near 361 W.
I have no changes to get my hands on Purify amp in my country. So I guess I would blindly buy M23. At least I will be future-proofed in amp section.
You can get more power for less, in most places. the NAD is nice, but you can get the same Purifi module for far less (I have the C298, which I bought used). Or order the Purifi from Alan March-
Purify modules benefit greatly from good power supply, and one in M23 is definetly better. Also with C298 I will surely have upgrade itch)
M23 will close amplification question.
Nevertheless C298 is still a great option.
They’re both transparent,I’ve heard both,zero difference except to your wallet.
