What is the measured SPL at your main listening position when set to -20, -10, or -5? I don't see a problem turning it up. Unless you hear distortion/clipping - what is the issue you are trying to solve here?I Hello!
bought the M10 V3. But I have to turn it up to -10 to -5db to hear vinyl records loud enough and about -20db for anything else.
So I bought the Fosi Box X5 pre amp. It's louder (even at the lowest gain) than the internal phono pre amp. But there is a hum which I can't eliminate.
I will return it.
Does it make sense to buy 2 Fosi V3 Mono to have more power? And: Is it better than the build in nCore in the NAD m10 V3?
What is the maximum of the volume scale?
Bare in mind it is only a 100W amp.
Also - what are the speakers specs, impedance, sensitivity, etc.
