Mike_Trueman
- Joined
- May 9, 2024
- Messages
- 648
- Likes
- 523
Are you able to see your logs on your network?My NAD suddenly is unable to check for updates and the list of available services to connect to is empty. Meanwhile it is controlled by the app and I can see it on my router’s DHCP leases list though I cannot ping it. What can be a problem? Do I need to hard reset it and loose all Dirac settings?
You are able to see your diagnostic logs without having to send a support ticket. You can enter the following command in your Web Browser: "IP ADDRESS/diag?print=1". Replace the IP ADDRESS with the actual IP Address of your M10 and you will be able to see the log.
Example: http://160.168.0.532/diag?print=1
