NAD M10 V3 BluOS STREAMING AMPLIFIER
Hello!
I must activate AV-Mode to get the TV sound lipsync (it´s still a bit delayed in comparison to the TV). Is there a disadvantage in sound quality when I hear music?
I saw news Qobuz Connect became available in September but I see no updates. Is it fake news?
Hello!
Subjectively I never heard a difference between AV-Mode on/off, but have not found a technical description of the difference. I assume it only does some extra buffering in the delay time.
Thanks!
I haven‘t tested it yet.
And yes, unfortunately there is no technical description.
I bought the M10 V3 as a replacement for a NAD D7050. I'm finding the KEF KC62 incompatible with the amp when using sub 1 @ 80hz the sub just cuts bass at low volumes when it shouldn't. Dirac calibration helped a little but didn't eliminate the issue as certain tunes with low bass still causes a problem. I also used dual pre-outs and let the sub handle the cross over and it happens but at even lower volumes. Wondering if anyone else has had sub integration issues of if it's the KEF not playing ball with this amp? Seems there are complaints of the KC62 cutting out sound at lower volume on other forums thinking of returning the sub and getting something else with perhaps a 12v trigger.
I am also using the 12v trigger on my NAD M10 V3 because it just always works with my SVS sub.
Do we need to wait on a bluOS update to get Spotify lossless audio on the NAD M10?
Over a year since the M10 V3 dropped: DLBC is still MIA.
We’ve seen this show before: promises DLBC on the M10 V2, then nothing. Now the cycle repeats for V3. How is NAD able to keep hyping features, but never delivers, without more severe consequences?
Call it what it is: vapor(soft)ware. This is getting old fast.
and yet I was attacked when I stated I doubt the longevity of key features in these super integrated amps or active speakers. wake me up when they guarantee a 5 year software upgrade road map and even better security updates for at least 7 years.
and also think about if they represent a security liability in your home network.
I would put these devices on a separate Vlan for sure.
ps. just curious. how were you "attacked"?
I don't bring up old grievances, and leave them. alone. I regret the times I did get into silly fights that required moderator attention.
But yes, I do mistrust audio companies' ability to keep updating last Gen products with advanced feature sets. if we want to discuss why, we can discuss on a different thread, because it would be utterly unfair to single out a NAD product.
Why did my NAD BluOS downgraded to 4.10.19? The latest version is 4.12.4.
Hmmm mine also did the same.
I know i had problems with the new version with DIRAC. Maybe they downgraded because of that. I lost all my Dirac saves because of the downgrade.
Qobuz Connect is a very welcomed addition but I find my iPhone being disconnected from NAD way too often. What’s your experience with this new feature?
