NAD C298 Stereo Amplifier Review
Rate this amplifier:
    Votes: 3 1.0%
    Votes: 32 10.7%
    Votes: 140 46.8%
    Votes: 124 41.5%
Have we figured out what NAD was trying to achieve with the custom mods? I’m curious what benefit they thought justified the slight deterioration in performance. Reliability? Speaker protection? The world wants to know.
That's disappointing, I'm sorry to hear it, good to make people aware of though.
Doing what I can. I would have thought that after Amir's devastating review of the T758 v3 AVR (which I deeply regret buying), NAD would devote some resources to repairing its own damaged reputation.
Not so much, apparently.
Like I said, if you already produce your own electronics it's probably cheaper to produce some extra PCB's than to buy finished OEM modules from a supplier. Especially if you, like @restorer-john mentioned, can optimize the design to reduce cost, or if you plan to add some extra functionality anyway (e.g. 12V trigger).
Looks like NAD has abandoned their "bang for buck" philosophy. Still a nice amp. but expensive.
I were you, I would cut back on eating out for a couple of years and save money to get the beautiful master series. :)
isn't it about twice the price of C298? which makes it more expensive than Benchmark AHB2, which measures better? unless one needs more power, I'd go for the Benchmark at that price
So that stuff just supports the variable gain and trigger sensitivity? Seems like a lot.
I was not a fan of the status LED. On power up, it turns orange. If you hit the power button, it initially goes red making you think there is a fault. But eventually switches to blue saying it is on.
Since I am red/green colorblind and the LED is small, I cannot discern the orange-to-red shift. For me, it is just orange -> blue. :)
Mine is hidden in a cabinet in the corner of the room and turns on when my RME sends it a signal. So for me it is invisible, just the way I like it.
And has a totally different power supply.
It would be interesting to use a Kill-a-watt on the C298 to determine how much power it uses while in standby mode waiting for your RME to turn it on. Some of these implementations are not very energy efficient.
Standby power must not be > 0.5 W (regulatory since 2013). NAD C298 Specs.-->
Interesting to go through this review side by side with the M23. There are clear improvements in the design of the M23, but not to a great extent, and not in terms of power (C298 measures a hair higher at the knee in each case, actually).
@amirm I don’t suppose there’s still a chance to get the reactive load test on the C298 that you did for the M23 but which doesn’t appear here?
This was a long time coming. Thanks for testing, and to whomever sent it in!
The NAD 2200 power amp from 35 years ago would be audibly indistinguishable, and can provide even a little bit more burst power (which is what counts for music reproduction) into 4 ohms.
And can be had for about 200 USD regularly where I live. Of course some of them may need some TLC.
This is a review and detailed measurements of NAD C298 stereo class D power amplifier based on Purifi Eigentakt modules. It is on kind loan from a member and costs US $2,399.
The unit is quite heavy for a class D amplifier. The front is plain as most power amps are. I was not a fan of the status LED. On power up, it turns orange. If you hit the power button, it initially goes red making you think there is a fault. But eventually switches to blue saying it is on. Back panel shows some nice features such as fixed and variable gain and selectable level for trigger input (auto power on):
I realize NAD reserves their exquisite casing for their "Master" series but if I am paying $2,400 for an amplifier, I expect something better than stamped sheet metal cover and utilitarian binding posts. FYI the vents on top are only on top of one amp heatsink and not the other. Seemingly they went for looks rather than usefulness there.
NAD C298 Amplifier Measurements
I started measuring with fixed gain and was pleased to see the gain close to our nominal 29 dB:
Distortion is vanishingly low at -120 dB and it is noise that brings it down to a very respectable 100 dB SINAD:
I was hoping to get even better performance by lowering the gain to 15 dB. That did not happen:
We actually have more distortion and some mains noise as well! :( So back to fixed gain for the rest of the tests. Here is RCA input:
Dynamic range is excellent:
Multitone distorting is very low but with some increase at higher frequencies:
Which is reflected in dual 19 and 20 kHz tones:
Frequency response is flat and load independent which is great:
Crosstalk is excellent:
Let's see how much power we have:
That's quite healthy and gets even better if we allow 1% THD:
No, I didn't test the bridge mode. Stereophile did and it does pump out a ton of power.
Here is the 8 ohm power:
Sweeping with different frequencies shows unhappiness only when frequencies go above 5 kHz:
Power on is silent although there is a pattern in the idle noise which should have been caught and eliminated:
My target here is 1 mv and it is exceeded when unit is powered off so that may cause a pop.
The amplifier is stable on power up but has the same strange variable pattern:
If you want an amplifier with state of the art class D module in it, your choices are usually from smaller independent companies. NAD is one of the exceptions in major brands to offer an amplifier with Purifi module in it. That comes at a premium in retail cost due to channel and brand overhead. The C298 delivers excellent performance with just some minor issues in variable gain and idle noise.
I am going to put the NAD C298 on my recommended list. But if I were you, I would cut back on eating out for a couple of years and save money to get the beautiful master series. :)
Manufacturers Specifications:​
ANALOG AUDIO INPUT/LINE OUT​
  • THD (20 Hz – 20 kHz)
  • <0.0005 % at 2V out
  • Signal-to-Noise Ratio
  • >120 dB (IHF; 20 Hz – 20 kHz, ref. 2V out)
  • Channel separation
  • >110 dB (1 kHz)
    >100 dB (10 kHz)
  • Input impedance (R and C)
  • Single-ended: 56 kohms + 280 pF
    Balanced: 56 kohms +280 pF
  • Maximum input signal
  • >7.0 Vrms (ref. 0.1 % THD)
  • Output impedance
  • 390 ohms
  • Frequency response
  • ±0.1 dB (20 Hz – 20 kHz)
  • Maximum voltage output -IHF load
  • ≥>7.0 V (ref. 0.1 % THD)
ANALOG AUDIO INPUT/SPEAKER OUT​
  • Rated output power into 8 Ohms and 4 ohms (Stereo mode, ref. 20 Hz-20 kHz at
    rated THD, both channels driven)
  • 185 W at 8 ohms
    340 W at 4 ohms
    (Bridge mode, ref. 20 Hz-20 kHz
    at rated THD, both channels driven)
  • 620 W at 8 ohms
  • <0.005 % (1 W to 185 W, 8 ohms and 4 ohms)
  • >98 dB (A-weighted, 500 mV input, ref. 1 W out in 8 ohms)
    >120 dB (A-weighted, ref. 185 W out in 8 ohms)
  • Clipping power (Stereo mode, at 1 kHz 0.1 % THD)
  • >200 W
  • Clipping power (Bridge mode, at 1 kHz 0.1 % THD)
  • >690 W
  • IHF dynamic power (Stereo mode, at 1 kHz 1 % THD)
  • 8 ohms: 260 W
    4 ohms: 490 W
    2 ohms: 570 W
  • IHF dynamic power (Bridge mode, at 1 kHz 1 % THD)
  • 8 ohms: 1000 W
    4 ohms: 1100 W
  • Peak output current
  • >25 A (in 1 ohm, 1 ms)
  • Damping factor
  • >800 (ref. 8 ohms 20 Hz – 6.5 kHz)
  • ±0.2 dB (20 Hz – 20 kHz)
    -3 dB at 60 kHz
  • >100 dB (1 kHz)
    >80 dB (10 kHz)
  • Stereo Mode input sensitivity (for 185 W in 8 ohms)
  • Fixed Gain mode: 1.43 V
  • Stereo Mode Gain
  • Fixed Gain mode: 28.6 dB
  • Line In – Balanced and Single-ended
  • Variable Gain mode: 8.5 dB – 28.5 dB
  • Bridge Mode Sensitivity
  • Fixed Gain mode: 3.78 V for 620 W in 8 ohms
  • Variable Gain mode at maximum: 1.41 V for 620 W in 8 ohms
  • Bridge Mode Gain
  • Fixed Gain mode: 25.4 dB
  • Variable Gain mode: 14.5 dB – 34.5 dB
  • Standby power
  • <0.5 W
DIMENSION AND WEIGHT​
  • Gross dimensions (W x H x D)
  • 435 x 120 x 390 mm (17 1/8 x 4 3/4 x 15 3/8 inches)
  • Net weight
  • 11.2 kg (24.7 lbs)
  • Shipping weight
  • 13.6 kg (30 lbs)
Nice review Amir! I still have my 1980's NAD 3130 Integrated amplifier. It's a workhorse with a very pleasant
sound.
Performance/Headroom, which depends on physical implementation and system-level circuitry/configuration (thermal system, power supply section, ...).
Not without reason, the dynamic power is 750W into 2 ohms. The bridge mode also makes the custom mods necessary.
This could also apply to the C658/C298 combo:
NAD has added a gain stage to increase its headroom so that it works better with the DSP circuits of its room-correction software and tone controls. NAD concedes that this slightly decreases the M33’s signal/noise ratio, but with careful design and premium parts, and because the Eigentakt’s S/N is so low to begin with, the noise is still inaudible.
Source: soundstagehifi.com
Did NAD in the past had this level of performance before purifi modules ? If yes which amps were those ?
I don’t know the spec sheets for numerous models, but my C326 BEE is excellent.
The thing I like about NAD is they publish meaningful specs for their products, unlike comparable brands such as Rega or Naim for example who tell you almost nothing about how their products perform and NADs performance historically is usually good for the price bracket.
In general when looking at amplifier specs I’ve found NAD to have the best noise and distortion vs power output compared to the competition.
Why buy this when we have plenty of Purifi implementation with cleaner power, and probably better case? Maybe except the brand and retailer network?
Decent heatsinks.
Voted “great” based on measurements only. For the price, I would have expected closer to SOTA, or at least meeting the Purifi reference design specs. Still, nice to see a larger manufacturer implementing Purifi, but with that comes markup for distributors and dealers.
