Hello.
Can you please tell me if I can connect an active subwoofer to the RCA preout of the Nad 298? I would like to use the Eversolo DMP-A6 as a preamplifier but unfortunately Eversolo does not have a subwoofer output.
Thanks.
@nothingman
In fact I think you are right, the Wiim Ultra would also be fine for me (among other things it also has a remote control useful for basic functions) and above all any type of input and output.
I've used the Wiim Ultra with the NAD C298 for ~3 weeks now, and the combination is wonderful, so far.
Don't worry about using an unbalanced/RCA connection from the Ultra to the C298. Set both to 2V sensitivity, and you should get plenty of volume range on the controls. If you need more, you can change the 'pre-gain' of any input for the Wiim, up to +-10 dB. I goosed the HDMI path I use by +3 dB. Less of 'headroom' via unbalanced inputs is really not an issue.
The subwoofer integration of the Wiim is superb. I use a Y-splitter from the Wiim sub-out to my 2 subs. The Ultra and C298 are a solid and simple foundation for killer 2.2 systems for bass-heads.![]()
Another question.
I am getting a Rel T7X subwoofer, on this subwoofer the manufacturer recommends connecting it with a high level input.
They told me not to connect subwoofers to the amplified output of the Nad speakers, do you know why?
What other solution do I have to connect an active subwoofer to the Nad 298?
Thank you very much.
Thus, the quality and signature of your interconnect cables, the dynamics and tonal shadings of your power amp all contribute to the final sound you are used to hearing through your speakers.
@nothingman
Sorry, the translator was not correct...
I wanted to say, that Nad (dealer) advises against connecting subwoofers to the speaker output of the C298, he says it could ruin the power amp?
Bearing in mind that via RCA I don't think it changes much...in any case, does the 298 have a pre-out output for subwoofers?
Sounds like your dealer is biased against high-level outputs, because they obviously don’t ruin amplifiers.
If the amp has a bridged/floating output (one that is not ground-referenced), and your active subwoofer inputs are ground-referenced, you are shorting the amp output to ground if you connect the sub inputs to the speaker outputs. That could definitely cause the magic smoke to escape.
I don't get it either. I use my REL line level input.I don’t get not using line level for sub input, but then again I don’t get using REL.
I doubt that the protective circuitry in the NAD amp will allow it to self-destruct. NAD typically provides ample overload/overheat protection.If the amp has a bridged/floating output (one that is not ground-referenced), and your active subwoofer inputs are ground-referenced, you are shorting the amp output to ground if you connect the sub inputs to the speaker outputs. That could definitely cause the magic smoke to escape.
I don't think so.Ok yes I saw the photos of the 298 they show two RCA outputs, I assume they are variable, so I can connect active subwoofer.
I assume you have used machine translation. as "mass" instead of ground/earth is a common machine translation issue.Ok yes I saw the photos of the 298 they show two RCA outputs, I assume they are variable, so I can connect active subwoofer.
I also saw the link, but I got a bit confused with the explanation of living in France, Northern Italy, Germany and moving to England... -
I don't understand the mass issue so I should only connect two rows to the amplifier output and leave the black ground one free?
I don't want to risk it, I'll go with the RCA ones!
At this point it is better to use the classic Preamp (low level Input) with a Y RCA cable connected to the Nad (these Rel subs are very particular) but on a two-channel system they are fabulous.
See you soon.
I don't think so.
Yes, it does.Really? You would know given all the equipment you’ve had your hands on, and I’ve never used line-out from a power amp, but doesn’t it just pass through whatever it receives from the pre-amp in terms of voltage?
They simply relay out whatever comes in. They are not variable since there is no control to vary them. Also, you cannot roll off the main speaker output.Ok yes I saw the photos of the 298 they show two RCA outputs, I assume they are variable, so I can connect active subwoofer.
Yes, it does.
You will be limited in how you can integrate the subs with the amps.
What are you feeding to the NAD? Have you considered simply splitting the input to the NAD?
