- Joined
- Oct 25, 2019
- Messages
- 12,473
- Likes
- 18,124
Corrected.![]()
Now if we could do something about all the old knob twiddlers around here we would be OK.
Corrected.![]()
The same amplifier should be in C368 integrated?
Bust Mode:You engage the rarely used and massively un-PC "bust" mode at one point, you saucy devil.
Bust Mode:
Hhmmm... what is better at $900 ?
I'd love to see it measured as well. I love mine... nice and simple, cheap and cool, and very compact and light. Sure there are some drawbacks (theoretically) over a AB topology... but I forget all about those when I pick one of the PA-1's up!For $600, you can go the monoblock route with a pair of Emotiva PA-1’s, Would like to see it measured.
Ah, makes sense now.PS. That also explains your strange crosstalk result.
I googled those blue binding posts and found no details regarding a colour code or anything like that. I suspect it is a off colour simply to get the users attention.Good review @amirm
So what's with the blue negative binding posts? Is that some new EU mandated directive I don't know about or is it an indication they are not actually sitting at chassis earth. Notice the BTL connection- that means one amp is out of phase with the other in normal operation- BTL is taken from the two hots otherwise. (they did that with the old 2200)
I wish there were some standard for such amplifiers. Labeling amps red and black has caused plenty of troubles when they really are differential outputs. Like when people use the speaker input to a subwoofer from one of these. Ouch!It's likely to mean neutral, but not actual earth (or 0v). For multi speaker installations and speaker switch panels, especially ones that switch only the hots, you'd run into trouble with shorted amplifier outputs otherwise.
My 15 year old Krells, with differential outputs have red and blue for the colors.
Amplifier Bridged Mode Performance
Your Krells aren't bridged, but they do float the negative above and not connected to the chassis.
