Hi people what are the best pre amplifiers options for nad c298?
similar, like above. Rme adi2 + nad c298 + klh 5.
I replaced the benchmark ahb2 with the c298.
why?I replaced the benchmark ahb2 with the c298.
It's not worse. Depending what dac/pre you use could be slightly better but most likely nothing audible. I use it with Denon x3700Is c298 better than m33?
why?
If two digital sources can suffice, I highly recommend RME ADI-2 DAC. For the following reason; (1) great headphone amp (2) you will get parametric EQ (3) great sounding DAC.
Here is my setup: Node, RME, NAD C298, KEF LS50.
Edit:
You can get output from your computer to RME, through USB, and you still have optical and another Coax for other digital uses. RME ADI-2 DAC is not technically called pre-amp, but some fellows here recommend it, and I'm very happy with it.
I think that may depend on the TV, but I am able to do so. In fact, I'm able to attenuate volume even using my Roku remote. My TV is a 10-year-old Samsung smart TV.With this chain i have a question:
If i use eArc from the tv to the node, then pass that digital signal to a dac. Would one still be able to attenuate volume using the TV remote?
Exactly that will be the case. Here is the implementation of the bridge mode in the C298/M23/M33 (channel-matching of the left and right purifi stages): LinkI suspect that it is possible but that not any two randomly-chosen channels will work.
tbh, haven't tried this since i'm using fixed volume on the Node and the Rme's remote for volume (and switching, due to different sources)With this chain i have a question:
The present chassis does not seem to be suitable in design for that.
No.do you know if you can access the power amp section of the M33 without going through the M33's digital input stage?
No.
And this is probably one reason why M23/M33 have a bit more output power and 'sound' better than a C298:
Dual Mono Layout vs. Stereo Layout with a lower total capacity.
The power supply of the m33 resembles the 298 more than the m23.No.
You can't compare a full chain against a power amp.The C298 ... measures cleaner than the M33.
