JRS
I have a post above--may wish to check out this supplier.As far as we know that is the only Purifi Eigentakt amplifier module on the market now, with more to come soon.
VTV has been widely discussed (including several threads specific to VTV). Use the forum search for "vtv purifi".EDIT: Hadn't read the entire thread, see that this has been mentioned. Anyhow still curious if anyone has experience with VTV.
Thanks. And ouch--not only do I feel a fool for touting these, it appears to be a can of worms is lurking under the lid such that I gonna have to give this some deeper consideration--so glad you prevented me from an impulse purchase I may have regretted.VTV has been widely discussed (including several threads specific to VTV). Use the forum search for "vtv purifi".
He reassured you about what?I just wanted to add that there were some strongly worded criticisms of VTV lack of quality control posted here a while back. I have had absolutely no such issues—my unit is well made. Prior to buying it I asked the owner about this matter and he reassured me.
I just got my VTV Eval-1 up and running. I was a bit skeptical with the Class D and accounts of VTV issues... but overall very satisfied and impressed with the Eigentakt platform. Night and day upgrade from my Marantz PM6007 which was a bit under-powered for my Focal Chora 826s.I bought the Purifi Eigentakt Eval 1 from VTV and am totally delighted with it. Service and delivery were outstanding. I didn’t opt for the more complex models because no interest in upgrades available for them and wanted to keep everything simple. I use it with an RME DAC and they are a great combination. I can’t believe the high sound quality for the price. Consequently I strongly recommend VTV. It’s also good to have the convenience of an American manufacturer, though Nord and Apollon were very tempting.
What is your source (dac/preamp)? The hiss might be coming from your source rather than generated by the amp. Does the hiss level change with the volume setting?One question for you: I'm getting an audible idle hiss when you get about 6 inches from the tweeter. Have you experienced this with yours?
Unfortunately it happens with no source connected, but it’s very faint. It certainly gets louder when I add in the Schiit Lokius and my CXN V2 streamer. You can’t hear it from the listening position and/or when music is playing.What is your source (dac/preamp)? The hiss might be coming from your source rather than generated by the amp. Does the hiss level change with the volume setting?
I’ll do some more troubleshooting. Thanks.I have had no such problem—absolutely dead quiet. Hope you solve this issue and enjoy.
This sounds normal. I don't have the numbers for your system, so I'll calculate for mine. FWIW, I hear hiss with my ear directly in front of the tweeter at a distance <= about 4 inches.One question for you: I'm getting an audible idle hiss when you get about 6 inches from the tweeter. Have you experienced this with yours?
Wow thanks for the detailed answer! I assumed it was normal, but this is my first legit speaker/amp set up and wasn't sure what was expected. I love this forum and the number crunching. Now... gotta go find the TI-83 in the basement.This sounds normal. I don't have the numbers for your system, so I'll calculate for mine. FWIW, I hear hiss with my ear directly in front of the tweeter at a distance <= about 4 inches.
Speaker sensitivity = 88.5dB @ 1W re 8Ohm load, 1 meter distance
Amp (C298) SNR = 120dB, A-weighted
Amp max power re 8Ohm load = 185W
SPL of noise @ 1 meter = 88.5dB + 10*log10(185W) - 120dB = -8.8dB
SPL of noise @ 4 inches (assuming +6dB per halving of distance in the near field) = -8.8dB + (6 * log2((100 / 2.54) / 4)) = 11dB
There is some hand waving here WRT measurement bandwidth, so I would expect to actually hear a few dB lower noise than this, but it is unsurprising that the hiss is audible above the ambient noise in my room. While a full-band measurement of ambient noise in my room gives about 35dB, most of that is low frequency and ambient noise level is much lower over the frequency range of the tweeter's response.
I actually just figured this out... totally forgot my Topping A90 has a pre-amp mode (use as my headphone amp in my office). Installed it after the streamer... everything is dead quiet now. I guess the CXN in digital pre-amp mode adds a fair bit of noise to the signal.This sounds normal. I don't have the numbers for your system, so I'll calculate for mine. FWIW, I hear hiss with my ear directly in front of the tweeter at a distance <= about 4 inches.
