NicS
Big Aphex Twin fan BTW….Sort of, see the product sheet on their website for she full set of combinations.
There is nothing cursory about this:It is a shame that the poll results indicate no interest in the actual performance of the device rather a cursory look at the conclusions and this when no mc testing was performed.
The gain setting would not have an impact on the overall review. Same frequency response error would be there regardless. With the tested gain being kind of in between MM and MC, the evaluation was more or less completed for both. I was not going to double the work just because.In view of all that, I'm really puzzled you are now quite reluctant to measure the MZX in the use case for which it appears to have been optimized -- namely, with a low-output MC cartridge.
The design concept is enough for me to interpret the ultimate performance of this device. Your MM measurements prove this as being the best phono device tested so far, as you say, the measurements are compelling so, MC performance will be as good or better than anything else.
By cursory I assumed it was plainly obvious that I was talking about the response to the poll by members who know so little about audio as to skew the results by being dumbstruck by a completely inaudible, measurably insignificant and easily remedied (already done by the designer) out of band abberation exactly the same as a class d non pffb high frequency peak of 1.5 db just above 20khz where in that case is not worthy of any concern
Your not recommended conclusion based solely on the contrived opinion of a glaring defect being present didn't help matters when the younger, newer members are so impressionable.
I don't even care that you refuse to make a checklist so you won't miss a part of your normal test procedure. Except if a product is designed to address absolute transparency for an intended function and what the result would be under those conditions (0.5mv, 50 ohms, 62db gain) is completely ignored. Or, the LBM has a method specially designed to reduce port resonances that can't be confirmed because you forgot to measure that port output we could care less about on the last 200 reviews where it was 20db below the signal level, by how much did the LBM improve it. Who knows.
On to more important things: JAYs 4 LADs 2, bottom 7th
It's nice to see someone use EMPIRICAL (a fact that you know is occuring but have no measurement proof to present to others).
There have been times (such as at my mother's house) when I needed to run 12 or so feet from the DUAL 1229 turntable to the APT/Holman preamp (one side of the fireplace [at this time not being used as a fireplace] to the other). Instead of converting to balanced, I just run about 3 ft. to an ART Phono Pre whose line level output I run about 10 ft. into a line in on the APT. Because I had the ART on hand, it was a quick & simple solution that did not seem to have any negative results.
So, since I have no pre-amps (or other gear) that have balanced inputs, I'll wait. But I do want to try this conversion on my Technics SL-M3. Hopefully I will obtain a Micheal Fidler preamp next year with ballanced inputs so that I have a reson to do this.
It's a hobby, at least for me & I enjoy my personal experiments, for better or worse.
Nice to see an APT/ Holman preamp mentioned and still in use. I enjoyed mine until it died some years ago…It's nice to see someone use EMPIRICAL (a fact that you know is occuring but have no measurement proof to present to others).
They are pretty easy to have rebuilt, if you still have it.Nice to see an APT/ Holman preamp mentioned and still in use. I enjoyed mine until it died some years ago…![]()
Sadly it went away years and my APT Model 1 power amp as well. Sad to see them gone but I’m very happy with the Mark Levinson units that replaced them.They are pretty easy to have rebuilt, if you still have it.
The challenge there is room modes. It is quite common to have one in 40 to 50 Hz. If so, this gets added to that, causing even more boominess.Strange RIAA deviation, although we are talking about 1.5dB at 40Hz which shouldn’t be too audible.
This frankly is a lot of nonsense. Every review without exception has this and that person saying everything that is measured is likely or guaranteed to be inaudible. It is so common as to be "exhausting" as I read the responses early on in the review.I'm a bit late to this party, but that's all well said. What you say is also also why I basically quit bothering with reading or posting much. The measurements are good to have, but the interpretation of them by many here is, generally speaking, quite often well off the mark and sloppy. Couple that with an apparent lack of curiosity by many about much of anything short of SINAD (or at least, an inordinate focus on it) and it's just exhausting.
I didn't want to get into a debate over this, since it's already been proven over and over, but here we go... When it comes to phono stages, SINAD measurements are quite often window dressing, or the "color of the car", unless the measurements are done correctly. You do not do them correctly because you do not connect a cartridge load. To be fair, Soundstage doesn't do them right either, nor does Stereophile. IHF and CEA standards require a load, and for good reason.You don't get good SINAD and then ignore everything else. Having good SINAD guarantees the company cares about transparency and true dedication to fidelity. So don't talk about it as if it is the color of the car.
