MYTH: "Your signal-to-noise performance is determined by the first gain stage."
GK.
A while back I was taken to task by someone via email for attempting to discuss the headroom versus noise trade off associated with the location of a volume control attenuator in the design of an analogue signal processing chain.
Apparently, I was some kind of imbecile for not being cognizant of the allegedly fundamental fact that, for all practical purposes, a systems signal-to-noise ratio is always entirely defined by the first gain stage.
I often see this BS being touted as some kind of truth as fundamental as the 2nd law of thermodynamics, or as verifiable as the fact that night always follows day. If you have an objection, then you are clearly some kind of technically illiterate dope who doesn't even know the basics!
In reality, anyone who regurgitates the quote in the title of this thread, ironically, reveals themselves to have next to zero experience in the design and analysis of analog signal processing chains (audio or otherwise).
Consider the following example (which is just one amongst countless hypothetical constructions):
We have an audio system and the majority of the system gain comes from the first stage - that being a MM phono pre-amplifier. This phono pre-amplifier has a voltage gain of 40dB (that is times 100) and an input-referred voltage noise of 3.5nV rt/Hz (for a [unweighted 20kHz BW] S/N ratio of about 80dB ref. 5mV). So, fairly typical figures for a good design.
That 3.5nV rt/Hz of input-referred noise is amplified to a whopping 350nV rt/Hz signal at the output of the phono pre-amplifier by its 40dB of gain.
350nV rt/Hz is obviously a huge amount of noise that will easily swamp out noise contribution of the following stages....
Right?
Well, yeah......
BUT
Believe it or not some of us strange folk don't find it particularly practical or at all desirable to listen to our systems with the volume wound up to 11 all of the time.
So we might typically incorporate this conceptually mind-blowing thing called a volume control attenuator somewhere in our signal chain. As a matter of fact, a location that it is often found is right at the output of the phono pre-amplifier.
For typical, casual listening in the evening, it would not be even remotely out of the ordinary to have the volume control set to give in the vicinity of 40dB or so of attenuation. This is especially so if you have a high-powered system with efficient loudspeakers.
Well, that 40dB of attenuation will effectively nullify the gain contribution of the phono pre-amplifier.
That volume control attenuator doesn't magically attenuate just the music signal whilst ignoring the self-generated noise present at the output of the phono pre-amplifier - it attenuates both signal sources equally.
So at the wiper of the volume control pot (or stepped attenuator or whatever) we are now back down to a noise signal voltage of just 3.5nV rt/Hz. I am keeping things simple here by ignoring the thermal noise contribution of the potentiometer itself, but that is perfectly OK as at 40dB attenuation even a potentiometer as large of 10kohms will present as a source resistance less than 100 ohms, so its noise contribution is negligible. People mostly stopped doing dumb things like specifying 5Mohm volume control potentiometers 30 years before the end of the era in which thermionic tubes were dominant.
3.5nV rt/Hz is quite unlikely to now be the dominant source of noise in the system. A power amplifier is generally doing good if it has an input-referred voltage noise significantly less than 10nV rt/Hz.
Now if that volume control potentiometer is followed by a moderate amount of active signal processing circuity such as cascaded active crossover and/or tone-control/equalisation filter stages, then these are almost certainly going to be the dominant source of self-generated system noise almost all of the time by maybe an order of magnitude or even two.
And before someone pipes up, yes, the contribution of record surface noise changes the outlook and relaxes hardware requirements significantly, but that is completely irrelevant to a technical analysis of the contributors to a systems total self-generated electrical noise.
Well that is my rant for this evening.
Don't really understand what you are driving at.
The title of this thread is on "signal-to-noise performance". How can one improve "signal-to-noise performance" downstream when it is already baked into the signal by the first stage? You can reduce the amplitude to reduce both the signal and the noise, but the signal-to-noise ratio is not, and cannot be, improved by what happens downstream.
The absolute value of the noise does matter, since it will be, in the end, compared to other absolute values, such as the threashold of audibility or background noise of the room. If you only need a modest max listening volume, you can lower both the signal and the noise by effectively lowering the gain of the latter stage(s) by attenuating the output signal level from the first stage. You may be able to lower the signal noise to below the noise floor of the room, and amke the noise disappear. But that will also impose a lower maximum listening volume, all limited to no better than the initial "signal-to-noise performance".
Obviously!
You can't. You can only make it worse. And if you blithely disregard the role of any attenuation in the signal chain (eg the volume control) and therefore assume that a first stage that provides the majority of system gain is the sole bottleneck then you are set on a path to design a system that is overall noisier than it should be.
Who on earth said otherwise?
So, why is "Your signal-to-noise performance is determined by the first gain stage." a myth?
Why start a thread when you are unwilling to defend you arguments or acknowledge that they are mistaken?
Hi @GK.
I am as lost as @NTK is.. The output of the first stage is what is presented to the rest of the system .. if it isn't good, what do you expect will happen, regardless of how perfect and high performance the rest of the stages are? To repeat @NTK
Not sure what you are driving at. I re-read your original post and ,, am drawing a blank ..
Hi @GK.
The best thing you can say for the first stage is that it sets an absolute limit to the achievable noise performance.
Stating anything else in absolute terms is teetering into mythology.
When you throw a sufficient amount of passive attenuation into the signal chain the first stage is no longer reliably a system bottleneck to signal-to-noise ratio performance. At some point, other stages will potentially begin to degrade the noise performance more than the first stage does.
In an analogue signal processing chain, the best location for any passive attenuation, as far as noise performance is concerned, is at the very end of the chain (the worst is at the input), but that is seldom practical due to signal headroom limitations. So some kind of compromise needs to be found.
I thought that I gave an adequate example to put some practical numbers into peoples heads to give some perspective on just how quickly things can go south - thinking that your design work is all done and dusted with the first stage, as far as noise goes, is often rather optimistic thinking.
Here is a really basic example. Which stage is negatively impacting the signal-to-noise ratio the most? (specified noises are unweighted, input-referred).
At what level of attenuation is the contribution of the two stages equalized?
Now what if there is an active filter stage (tone control or active crossover) added between the volume potentiometer and the power amplifier, which will typically have much higher input-referred voltage noise than 10nV rt/Hz?
I don't understand your point or what you are trying to convey. The first stage is the DETERMINANT as in it creates a ceiling of performance. It is impossible to have a better S/N than that provided by the first stage. You can only do worse.. Actually you shall do worse... "Shall" not "will". ... So very seriously... What are we discussing here???
From The Oxford Dictionary:
determine
/dɪˈtəːmɪn/
verb
  1. 1.
    cause (something) to occur in a particular way or to have a particular nature.
So ...
@GK. I’m interested in this topic and I’ve read examples like this from the Radar Tutorial re: cascading amplification -
  1. The first stage of amplification should have the lowest noise level. This is because the first stage noise will be amplified sequentially in all subsequent stages, so the smaller they are initially, the smaller their contribution at the amplifier output.
  2. The last amplification stage must have the lowest gain of all stages. This is because all previous amplification stages will be amplified in this stage.
As a practical matter, I bought a new amplifier that has a high/ low gain setting. Based on the above, I do not attenuate the output from my CD player (an option) but keep it maximum. I set the gain in the amp to low which allows me to turn up the volume control on my pre-amp. Are you suggesting a different arrangement? BTW, I’m not an EE so analyzing the circuit is beyond me.
Obviously!
LOL. Thanks for the education.
Nowhere, in any of the above, have I said or insinuated otherwise. I even explicitly stated that myself.
FFS
With you? I have no idea.
I get it
s:n can't get better than it is at the first gain stage, but it can get worse, so s:n performance is not determined by the first gain stage
Not really.
That is nonsensical. The first stage can can most certainly be the dominant source of SNR degradation, but when a passive attenuator (volume control) is introduced into the signal chain the first stage is no longer necessarily or even perhaps typically the dominant source of SNR degradation.
This topic has been well understood and documented for many years. Attached is a white paper from Agilent/Hewlett-Packard/Keysight (Fundamentals of RF and uW Noise Figure Measurements - 5952-8255.pdf) which details the effects on noise figure in multi-stage systems.
Obviously, adding an attenuator to the signal chain can degrade SNR. For example, adding a 120 dB attenuator to the analog output of a state-of-the-art audio streamer would diminish its SNR to nearly zero!
In so far as the thermal noise of a passive attenuator due to its resistance can be neglected, attenuating a signal by itself does not effect the SNR ratio. Quoting myself :
The elephant in the room is that the volume control attenuator when introduced into a signal chain breaks down the gain distribution that previously made the first stage (well, the net sum of all stages preceding the attenuator, to be pedantic) noise dominant.
If what you say were true, then following the attenuator in my example with a 120 dB amplifier would restore the signal perfectly. Which of course it does not do in practice. This is because even independent of any thermal effects the signal amplitude is driven into the system noise floor, and it cannot be recovered.
What I said was 100% true. I can't believe that anyone would argue otherwise. If the amplifier was noiseless it would indeed restore the signal. Of course, at 120dB of attenuation, the signal has been reduced well into the noise floor of any practical amplifier.
as there are other stages that can make it only make it worse?
