I’d love to hear a representative from Brooklyn comment on this review.
Zero upside for them unless they play the "must be broken" card. Which I don't think they can or would.The performance of this 5k steamer/dac should embarrass Brooklyn . Will it ?
VS the US $4999 Mytek Brooklyn Bridge II solution, there will be a lot of money left over then. Why not take them and visit the real deal for example:
It will be a nice travel memory, plus when you get back home you STILL have a solution that is better than the Mytek Brooklyn Bridge II Streamer.![]()
I called it broken due to a $5k price tag.Y’all have lost your minds when SINAD of 98 is "broken".
Doubt it. They might use some Topping gear for checking their own equipment.I’m sure Brooklyn can afford to buy Audio Precision equipment to test a 5K streamer/dac !!
Don’t they have any at their place ?
Y’all have lost your minds when SINAD of 98 is "broken". It’s audibly transparent. Of course it’s not worth its price, but that should be an asterisk independent of the technical review.
Yep, we know.Mytek and 5k USD discussion - there is clearly a market for this things. And lot of people just don’t care about the measurements or objective performance. ASR is considered to be “SINAD cultists” by sizable part of hifi afficionados. Trust me, I know that lot. you have people agonising about differences between 2 fuses, or even better, even the DiRECTION of the fuse (whcih costs 5.000)
BTW 5k USD is considered dirt cheap in high end. You can get PC with fancy name and lot of linear power supplies inside for 25k and it is considered “good value” by some.
Even this graphic is lousy. The red text overlaying the device is hard to read and there is a tilt to the width measurement line. If space was cramped, use a partially transparent backing block to allow readable text. Uggghhh, not high-end.
