Mytek Brooklyn Bridge II Streamer Review
Rate this streamer/DAC:
    Votes: 350 86.8%
    Votes: 38 9.4%
    Votes: 5 1.2%
    Votes: 10 2.5%
Seems like using a linear power supply with a big transformer inside the cabinet generates bad SINAD , no matter how good the supply is . Magnetic pollution.
One can mitigate this by strategic part placing and routing techniques for the PCB layout, minimizing inductive pickup loops. But of course physical distance is key.
Why the hell did they try to cram all of that in such a small box? I wonder how much better this would have performed in standard rack-size box? Well, and with competent engineering.
They could have saved half the space and problems with a small outboard switch mode power supply :) just saying
The designer of this is probably up to his eyeballs in greed shit
Well, the actual electronic design engineer may have been aware and would know what would be required to do but the product managers and bean counters said "no, your 1st production prototype is good enough and we need to get this product out of the door asap!"
Mains noise is somewhat of a badge of honor in highend circles,as it means tubes or oversized PS caps,a little vintage,etc.
However this one is a whole different story as the pattern is not the inclined one starting from 50 or 60Hz and falling but is getting stronger as the freqs go up.
Someone probably got cheap or greed there trying to pack everything in such a small (Mytec's aesthetics was never my cap of tea) case.
With that choice of filter is broken in my book.
Thanks Amir!
Another DAC with a slow filter…
This is what a recording of the speaker output looks like (48 kHz REW sweep, 0-20000 Hz, recorded at 192 kHz).
Marantz SR-7013:
A proper filter as a comparison (Denon AVR-4306):
it is needed some courage to sell a 5k piece of this when you have 200 bucks better products...
Wow, my Matrix streamer basically has the same functionality and cost around $1k - and has good measurements
It doesn't have a touch screen, though. I guess that's worth $4k.
A RPi with a nice touchscreen, an "audiophile" case and a good inexpensive pre and DAC would not total more than $$550 and would be better than this. If you really wanted to splurge on the pre you could get up to $900. Yes, more boxes, but better performance and a much more usable touchscreen.
Ouch.
For that money it should at least measure well before you start looking at the features. Adequacy, given that the performance issues might not be that audible, is not good enough. Hard fail.
I think it's another product designed with a 'just good enough performance' mentality. I suspect it's transparent enough in practice but way off beam now technically when all these super-dacs are around for a ton or two these days. That slow filter may appeal to ignorant audiophools, but surely that could be fixed to work properly? Would a simple shield around the transformer be enough to properly reduce its interference?
Will that internal computer go so out of date it can't be used in a few years time? Maybe I'm confusing the functionality with the early now ten or so years old Naim streamers which I gather glitched themselves almost into non-use - they offered a not very generous trade in on new products (a measly ten percent or so off a new one) late last year.
Let alone sealing the transformer with a steel shield cover, even better yet with mu-metal for that price. But apparently who cares, right? :)
Thanks for the test, measurements Amir.:)
How many DACs in the + $ 3k price range have you tested that you consider worth that price?
___
Ooof. Give me a Wiim+Topping DAC over this any day
VS the US $4999 Mytek Brooklyn Bridge II solution, there will be a lot of money left over then. Why not take them and visit the real deal for example::D
It will be a nice travel memory, plus when you get back home you STILL have a solution that is better than the Mytek Brooklyn Bridge II Streamer.;)
Just a quick note in their defense. The Mytek is actually a server and can store content. Not that this is very useful these days with streaming and such but it does have that functionality as a Roon core above and beyond a standard streamer.
I have an almost identically looking Mytek Brooklyn DAC+ released back in 2018 and I wonder how it measures and what (apart from appearance) it has in common with Brooklyn Bridge II.
