Brainvoyager
- Joined
- Sep 14, 2026
- Messages
- 11
- Likes
- 19
Hi everyone,
I wanted to share my current system setup after some recent upgrades. I've spent a lot of time fine-tuning the synergy between components, especially around DSP and amplification.
Here is a breakdown of what I’m currently running:
Overall, I'm absolutely thrilled with the soundstage and clarity I'm getting now. The room correction really tied everything together, especially with the sub integration. I’d love to hear your thoughts on the setup, or if anyone else is running a similar combination of Eversolo and Arcam power.
Cheers!
- Source & Preamp: Eversolo DMP-A10 streamer/DAC/preamplifier, actively utilizing its built-in room correction.
- Power Amps: Two ARCAM PA240 stereo power amplifiers. The DMP-A10 hooks up to both via balanced XLR. I'm running them as monoblocks in dual-mono mode (vertical bi-amping).
- Cooling Mod: Since the ARCAMs run quite hot, I placed a custom rectangular frame with three variable-speed fans on top of each amp. They pull the warm air out and vent it into the room. Without them, the amps get scorching hot; with them, they stay completely cool.
- Mains & Switching: An IsoTek Aquarius power conditioner handles the juice. I'm using the 12V triggers so the Eversolo switches both ARCAMs on and off automatically.
- Speakers: Bowers & Wilkins 702 S3s running full-range (no high-pass filter on the Eversolo to make sure I get their full potential). They sit on IsoAcoustics Gaia II isolators with zero toe-in.
- Subwoofer: Bowers & Wilkins DB4S. The crossover is managed entirely in the Eversolo and dialed in at 46 Hz. I'm using the sub's LFE input, so even though the DB4S could take a full-range signal, the Eversolo only feeds it 46 Hz and below. Phase and time alignment are also handled exclusively by the Eversolo.
- Vinyl Chain: Pro-Ject Xtension 9 turntable (bought as a bare deck) fitted with an Ortofon MC X40 cartridge. The tonearm connects directly to a Pro-Ject Phono Box RS2 via balanced XLR, which then feeds the Eversolo via XLR as well.
- Digital Transport: Shanling CD Transport ET3, connected to the Eversolo via USB.
- Cables: All XLRs, interconnects, and the USB cable are from AudioQuest. Speaker cables are custom-built 11 AWG runs (1.6 meters each).
- Room & Acoustics: Set up in an L-shaped living room with plastered walls, an area rug, and curtains on the left. The speakers are spaced 2.5 meters apart.
- Listening Position & DSP: The main listening spot is a sofa 2.5 meters directly opposite the speakers. I used a miniDSP UMIK-1 measurement mic to dial in the Eversolo's room correction from this spot, and I've also run the DB4S's internal room calibration. Extensive acoustic treatments are a no-go here due to aesthetics and practical constraints.
Cheers!
