reggiegasket
- Joined
- Jan 10, 2024
- Messages
- 13
- Likes
- 7
If it's just a remote "knob" to turn, that can easily done with existing IR
Where? Can you send a link to one?
To quote Kal, No knob.I bought one of the aliexpress IR aluminium remote controls as pictured below to replace/render the bloody awfulCambridge Audio CXN-V2 remote redundant. It was easy enough to program for volume up/down, power off/on, mute/unmute, skip back/forward but the menu function needed me to program/assign functions to presets 1/2/3 using the Cambridge remote then assigning the presets to F1/F2/F3 on the aliexpress remote, such as switching usb mode etc.
There may be a way to assign sub menu control on the aliexpress remote but I sorta worked around the issue
All working fine now so I’m a happy bunny, the Cambridge remote is now in the drawer.
Your CXN-V2 is Roon ready, so if you use Roon, you can control it with a Quickeys and rooMax. There is a bit of either f*****g around or spending money, but once it’s working it works great.I was waiting for that, yes I know there is no knob, find me a ir learning remote knob that will work with my Cambridge CXN-V2 without f*****g around and I’ll buy one.
It’s a lot more than £17. Assuming you have Roon, the easy button is to buy the RooExtend Box for $380 https://shop.rooextend.com/en-us/products/rooextend-box, $95 for the RooMax License, and the Xencelabs Quick Key for $99. https://www.xencelabs.com/us/store/...ym8feSZCfrhjx3r5Xkb9fUpgILf8hU4Ymqn9TLFRaXo_DMy aliexpress remote cost £17 delivered and does everything I need once programmed, how much is what you mentioned and would it work with Mac?.
This one is kinda interesting. Has IR learning capabilities and a knob for volume control. I wonder if the knob could be taken off and a nicer one installed.
This really looks greatView attachment 395970
Already linked in #264 along with a couple of alternatives. Also worth a look:Guys,
WiFi, bluetooth, built in battery, TOUCHSCREEN!! 35$
[EOL] M5Stack Dial - ESP32-S3 Smart Rotary Knob w/ 1.28
Product Status Notice This product is EOL (End of Life). Please order the new version: Dial v1.1 Description Dial is a versatile embedded development board equipped with a 1.28-inch circular TFT touch screen, powered by the M5StampS3 as the main controller, and includes a built-in rotary encoder...shop.m5stack.com
Not for me, and not when this thread started: there was next to nothing - everything was either not available anymore, or not existing yet -The devices are really not the issue. It is making the devices work with our equipment that matters.
I've used the MS Dial, and now Quick Keys. Both will control Roon, but neither will control my MiniDSP Flex. When I'm listening via Roon that's fine. When I change to vinyl, or CD, I can't control volume with either.Not for me, and not when this thread started: there was next to nothing - everything was either not available anymore, or not existing yet -
Hi Dr. Please advise us as soon as you integrated this. I have been using your RooADi and Surface Dial and I'm very happy. Thanks!This really looks great
I will order one today and see on how I can integrate this as a Roon Extension within rooExtend.
Best DrCWO
