my HiFi Journey after Year-1 with ASR =)
khaliss
California
Hi all,
Just wanted to share something after being on this forum for a year now... I do appreciate the community, this forum has been helpful (to some degreee) on my journey with this little hobby. I'm in my early 50s, a techie (line of work)... since my teens, I've always been fascinated with stereo systems. I remember my first exposure to HiFi gear in the mid 80s, my uncle (who lived across the street) had a Technics multi-component audio system & I was just in awe!
Anyway, this is my current system (after several iterations) in the "listening room" (this is where I hide if my wife doesn't want my annoying presence in the main living room LOL). I began with a very simple setup over a year ago, and it has kinda grown over time:
This is a "hybrid" 2-in-1 setup (half of it is Stereo 2.2, the other part is a 6.3.4 Atmos for HomeTheater)... this post will just focus on the 2.2 stereo side of it =) The point of this post is to share what I have, in case there are others (particularly somewhere between a beginner & intermediate "level" to HiFi) who might find some useful info to help them with the hobby as well.
Signal Chain setup
I ended up with this somewhat budget-oriented build:
  • Source: PC (it really is a versatile streamer/audio player with REW+PEQ PnP utility)
  • DAC: Topping E70 Velvet
  • EQ+tube pre: Douk Audio T8 Pro EQ
  • Preamp (& Source switcher): Musmys C2860+
  • Amplifier: Musmys E-406 (class A/B: 320/180 watts)
  • Transducers: Martin Logan ESLs paired with dual Klipsch R-12SW subwoofers
In-room response graphs: (screenshots below)​
Measurements for the Left and Right channels tell a story (I had AI run an analysis of the graphs):
1. The Baseline (Red Line): Running the ESLs without subwoofers showed the characteristic dip in the lower octaves and several room-induced peaks between 40Hz and 200Hz. While the "magic" of the panels was there, the weight was missing
2. The 7-Band Phase (Blue Line): Integrating the dual Klipsch subs and using the DoukAudio T8pro 7-band EQ provided an immediate lift in the low end. However, as the graphs show, this was a blunt instrument. It filled the "holes" but left significant "ringing" and unevenness in the transition zone
3. The Final PEQ Optimization (Green Line):This is where I think the utility of a PC shines (with REW). By utilizing Parametric EQ (PEQ) via REW & EQ-APO utility, and also plugging the ports on both the ESLs & subwoofers to change the roll-off characteristics, I was able to obtain a much tighter, more linear response.
A.I.'s take:
* Low-End range: The sub/low bass range is much more stable compared to the raw response
* The Transition Zone: The "mud" around the 200Hz crossover point was cleaned up, allowing the ESLs to breathe without being overshadowed by the subs
* High-Frequency: Note the roll-off correction at the very top end (10kHz+), which helps tame any potential "shimmer" into a more natural, fatigue-free presentation
NOTES:​
* I just use old clothing to "plug" the ports on my speakers & subs
** it's a small listening room, like the size of your typical master bedroom (320+ sqft)
*** the room is not acoustically treated (with laminate flooring), it just has a lot of "stuff" in there (exercise bike, SIM racing setup, etc) LOL
HomeTheater 6.3.4 Atmos:​
I should also include information about the other half of this setup, so it paints the whole picture on why I built the Stereo 2.2 side in an "unconventional" way. Again, this is a "hybrid" setup... I use this side when watching movies & shows, any content that has Dolby/DTS surround sound or Atmos mix, my sources are:
1.) Sony 4K UHD bluray player (no longer the Samsung BD player on the diagram)
2.) also have an AppleTV 4K streamer (connected via 1 Gbps ethernet)
The Musmys C2860+ preamp acts mainly as an audio source switcher (between the AVR & the T8pro) & precise channel balancer (left vs right signal level). Because of the way my listening room is laid out (& how cluttered it is), my right channel is actually almost 1db louder than my left channel from my sweet spot, at least that's what REW's SPL meter says. Also the C2860's volume is set at around 30% permanently, which serves as the "unity" volume for both the AVR & T8pro. When I calibrate the volume level for the front left & right channels (from the AVR), it's set at 0db... so this effectively means when I'm increasing or decreasing the volume on my AVR (because who doesn't love to use the remote control for everything? lol) & the Marantz display says it's at 60db, then it's actually at 60db... hope that makes sense.
This also relates to the T8pro's gain level (which sets a "hard" limit) for the PC. My Topping E70 is set to "pure DAC", which means it's at 0dB Fixed/Line Out mode... letting it send the strongest/cleanest signal possible. When I'm watching a Tiny Desk concert on youtube or listening to Tidal (or any 2-channel stereo content), I use my PC audio chain... it just has a warmer & holographic sound, with some "analog" flavor to it (maybe due to the T8pro's tubes?) compared to when playing from the AVR in "pure direct" mode. I use my wireless Logitech keyboard/trackpad for full control of the PC (like a remote lol), it has dedicated buttons to control volume, etc. I adjust the T8pro gain knob so that I'm within 90-100% volume from my PC when listening at normal levels, if I want to raise the "cap" of the PC's volume, I do that from the T8pro. =)
Looking at the 2.2 schematics - do you watch videos with that setup? HDMI to TV and audio to the E70?
Was wondering about the handling of delays.
Or is videos a different player?
Why the DoukAudio T8pro 7-band EQ?
Have you tried a DSP solution like dirac?
Keep your charts at 50dB range for easy comparison with the rest here.
Clones are not my cup of tea for many reasons but if it works for you, it works.
I second about this strange Douk gear.
My initial thoughts:
1) Good post.
2) TV is too high.
3) whats with the speaker stacking?
4) I don't like the equipment stacking. I'm paranoid about heat in fairness.
5) Back light is cool
6) TV backlighting is underrated imho, perhaps have a look into that.
7) where's the bar?....
Second that - low end response could potentially be tightened up further and be more consistent across L/R.
Yes of course, any 2-channel audio content (like Youtube concerts & "Tiny Desk") I watch it from my PC. I updated my original post to now also show the other side of the setup (which is the HT 6.3.4 Atmos part).
Correct, HDMI is purely video only, while all Audio gets redirected to the E70 at all times =) There is NO delay... video & audio are always in sync... my PC has plenty of horsepower to play lightweight apps (like Youtube & Tidal) & no latency at all when it comes to playing back Video & Audio. My PC does have a discreet GPU (Intel Arc A750) which has full hardware-accelerated AV1 decoding built-in... YouTube & other video streaming platforms can take advantage of the A750's AV1 codec because it offers better video quality at lower bandwidths.. and thus freeing up the CPU for other tasks, no stuttering in HD/4K.
My PC serves as my DSP to a certain degree (for Parametric EQ + room correction), thanks to REW & EQ-APO apps (which are both free software). I'm not sure why I would need DIRAC for a 2-channel setup, but I do have Audyssey MultEQ-XT through my Marantz AV-7702 for the HT side of the setup. I know it's not as a good as DIRAC, but for now I'm happy with it since this is really just a budget-oriented build =)
I updated my original post to now also show the other side of the setup (which is the HT 6.3.4 Atmos part), it explains more in detail why I use the T8pro EQ in the signal chain. To add, I also use the T8pro's EQ to adjust the band curve for late night listening (ex. boost lower bass a little bit), which is sort of a "Loudness" function, right?
It's all about how you want to allocate your resources and budget. You do seem to have some not so cheap components in it. Overall planning of the system and budget allocation is important. If one can not do try-and return play for whatever reason, it is always helpful to audition showrooms that might have a newer tech and might provide some clues in that respect.
If OP wants another device, a Bobwire XLR switcher would be awesome to switch the multi and two channel systems automatically.
I will try to do another round of measurements when I have the time (or feel like it, lol). I know the idea of "clones" is off-putting to many audio enthusiasts, but to me I don't think it's a full "clone"... I think Musmys just put it out as a marketing gimmick (cuz everyone reveres Accuphase), perhaps the basic design is similar, but the components will vary a LOT in quality & specs. I mainly acquired the Musmys gear because of my limited budget, and I like the specs on paper. Turned out to be a great purchase though... been using them for almost a year now, and zero issues... and they perform really well. I actually posted a mini "review" <LINK>
I'm totally good with my C2860+ for the time being, it's not only functioning as an XLR switcher... but also the master gain control & channel balancer, plus the VU meters are freaking cool... & matching look for the E406 amps =) ALSO, it has 2 sets of XLR & RCA outputs (total of 4 sets)... I'm using 3 out of those 4 sets:
XLR 1 = to E406 amp
XLR 2 = to BDS spectrum analyzer (cuz it's so darn cool also)
RCA 1 = to the Klipsch LEFT & RIGHT subwoofers
A straight-up XLR switcher won't be able to do that =)
1) Good post.
2) TV is too high.
1.) Thanks
2.) It may seem a little high, but I sit on a La-Z-Boy recliner, and when I'm watching something... I recline it down to around the 2-oclock position, so I'm actually facing somewhat up... it works out great LOL
3.) are you referring to the two bookshelf speakers? those are my front height speakers sitting on stands on top of the subwoofers (which are also sitting on top of nightstands ), that is intended due to limited space & I do need the height speakers to be at a certain height
4.) the only two equipment boxes stacking are the C2860 preamp (which is always cool to the touch), and the Marantz AV7702 (which can get a little warm, but the top side is free to vent out heat)
5.) thanks
6.) haha I'm good with the backlighting
7.) I would love to have a bar in the room, but simply not enough space
to anyone following this thread, I just updated the original post to also show the HT Atmos side of the setup in case you're curious about it as well =)
