My first visit to Axpona; The emperor has no clothes?
"I'm going through this exercise myself and am astounded at how unaccommodating and uninformed higher end shop employees are "
I believe that they are trying to explain to you what you should like, not to let you hear what you like...
Back in the day when there were hifi stores around, I recall one line sales people used when the switched in a more expensive component- Hear that deeper bass/ airier treble/ faster slam?
Admitting you couldn’t usually got you a dismissive sneer and the suggestion that you were deaf or stupid, probably both.
Generally, it takes a really good 5.0 or 5.1 setup to evoke something like the feeling of a live performance
Yup -- IMO no 2.0 or 2.1 system can create a sense of spaciousness like a carefully curated and adjusted (mostly to accommodate how the source recording was engineered) multi-speaker setup can.
I'd love to know how many, if any, presenters at AXPONA calibrated their systems and used room EQ DSP.
In my quick trip through the show on Friday at least a couple of the speaker presenters mentioned what they were dealing with and tried to address the acoustic issues in the rooms. I applaud any effort by the presenters in this action, however, it really comes to mind that these shows are more about “look and see what we have”. I heard a lot of good speakers sounding pretty so so, and a few that were pretty good, generally it is a bit hit and miss.
Probably, but are either accurate? Or could they ever be?
I appreciate that with electronically generated music it can be accurate to the mix because that is all there is but with traditional recordings and accoustic music?
Clearly we have been getting a sense of space from a 2-way systems to a greater or lesser extent for decades but that is either manipulated in mixing or semi accurate in recording because of too few microphones to define all the real space. This is evident by how big a change in imaging we get just by moving a speaker to a different location in the room, or moving furniture, amongst other things.
On top of that in a multi channel system how precisely do the extra channel loudspeakers need placing, in angle at least, relative to the listener to have any hope of recreating the space as opposed to simply creating some sort of a spatial experience?
If all multi channel does is create an equally fake but bigger or just deeper sense of space it isn't worth the money, encumberment of faff IMO ;)
You may not realize it, because it isn't what you meant, but the actual room may be what you were hearing as much as anything.
Thanks, I understand room acoustics quite well, after 50 years experience with home and studio audio. I was using "room" in the generic sense, but many of the exhibitors at Axpona do have at least partial treatment for their presentations. But I don't for one minute believe that equipment doesn't matter. Yes, the differences among well designed electronics are becoming smaller each year, but they aren't zero, and there can still be issues with compatability between gear. When you get to speakers and headphones, there are obviously a huge variety of designs and results.
Particularly since musicality is a characteristic of the performance on a recording, not any hardware.
I'd disagree with that, as a little band limiting, just enough subliminal noise, very gentle compression, maybe the gentlest touch of added wow if a vinyl player and even order harmonics amongst other things can add to the musical 'tune playing' experience. Make the bandwidth too wide, too much distortion above 20kHz (which sometimes *appeared* to modulate down to borderline audible frequencies) and especially bordering odd-order harmonics and it's a recipe for a non-involving experience, even if the overall measurements aren't too bad...
We're spoiled now though, as much of the above seems to be understood by those who need to know and sensibilities are more stable today apart from the very high end where products HAVE to be different to be noticed :)
Much depends on the type of equipment.
Non-zero doesn't mean audible. No one should be 'mismatching' gear.
Repeating all this again is tiresome. And ASR isn't the place to be waving a golden ear flag.
I'm out - I'm not "waving a golden ear flag", that is your projection on my comments.
But just because I believe in objective measurements does not mean that all devices sound the same, or are of equal performance.
That is reductionism ad absurdum.
New to this website. I stumbled on this thread looking to see if anyone else had a similar experience. I went to the show with a strongly favorable bias, expecting (wanting?) to hear some incredible systems. Visually, many of these systems looked incredible. Most of them - the vast majority in fact - sounded terrible. Wooly bass, harsh treble and shouty midrange. Even in rooms where I sat in the sweet spot were poorly done.
I recognize the difficulty in setting up these rooms, but the praise that these rooms were generating despite the really poor quality sound was a major disconnect. Literally, I thought, "the emperor has no clothes".
Wilson was probably the worst offender. I really wanted to like them, but they were just not great. Dutch and Dutch, Dynaudio, Joseph Audio, among others, were strong I thought.
You wouldn't? I guess that explains my hi-fi.
Unrealistic to imagine that reproduction from a pair of loudspeakers if ever going to sound identical to a real instrument, just think of their relative propagation.
Definitely not an easy lift. But as I’ve mentioned before my Omni MBLs could sound remarkably life-like, for instance with recordings of my son practising saxophone.
This was especially true when listening from just outside the room slightly down the hall from the speakers. The live versus reproduced sax became almost indistinguishable. In fact, some guests were fooled into thinking there was a live saxophone being played in the house.
Unfortunately that’s what a lot of audiophiles claim is their holy grail
It's a false goal IMO. My view is that if it sounds like a recording of the real thing then you're on the right track, because that's what it is!
The vast majority of audiophiles who use live music as a reference (I include myself), don’t do so under the illusion that perfectly realistic sound is going to be happening anytime soon.
Rather they generally use live sound as a reference for the direction they are trying to move towards - you don’t expect to ever reach it, but you can move further away or closer to that reference.
I think I’m pretty typical in simply wanting a sound system to reproduce or mimic certain aspects of live sound that I enjoy, though not necessarily all of them. For instance, when I hear a well recorded drum kit on a track. As somebody who has been around drums much of my life and played the occasionally, I find it really pleasing if the timbre of snare, toms, drumstick, cymbals sound authentic and timbrally like the real thing. But I don’t need nor do I actually want the full volume and dynamics of a drum transported into my room.
I would expect that somebody familiar with pianos would like to hear some pianos reproduce on their system in a way they recognize in relationship to the real thing.
(otherwise… why would so many pianists…. Let alone countless musicians…. Be so fussy about the instruments they choose for their particular sound character, if that character is never going to be reproduced accurately at all?)
As a person that have heard it: yup
But again, there is stuff that breaks the illusion, like knowing it's not a live instrument in the room for example. But this could probably be blind tested in some fun ways with someone in the room playing a guitar vs recording the same person and guitar and then play it in the same room.
I would love to be a subject in a test like this
I did this numerous times.
Since I was so fascinated about the comparison of live versus reproduced sound, many years ago, I began to record instruments that we play in our house (my son‘s saxophone and trombone, my acoustic guitar etc) as well as my families voices.
When I had various speakers I would do recordings sometimes of the instrument or one of my family speaking in the same room between the speakers, and then play that recording back, and close my eyes and compare. This was as much to get a feeling for the differences as for the similarities.
It was informal and not scientific. And I really would’ve loved to be involved in a really well designed live versus reproduced test. But I still feel I learned some interesting things, at least in terms of my perception, of what reproduced sound struggles with in terms of certain characteristics of real acoustic sources in real acoustic space… but also how surprisingly close simple stereo on good speakers can sound to the real thing in certain aspects as well.
Plenty of guests when played certain tracks on my speakers over the years have remarked about “ how real” it sounds. It’s not of course that it sounds perfectly real. But the concept of music sounding anything like real is not something most people even think about. Doesn’t occur to them.
So when they hear something that is so much CLOSER to real than they’d ever experienced, they can be pretty shocked.
And this also goes back to what I mean about how perfect sonic realism doesn’t need to be fully achieved in order for it to be a useful reference… you really can move closer or further away from that goal.
I've never been to a HiFi show and I'm sure any exibitors or manufacturers would be pleased about that. I don't think I'd be able to contain my contempt and criticism for snake-oil products and would take up valuable selling time for the reps arguing with them.
I'm unsurprised that the OP was "underwhelmed" by the demo systems because let's face it, they're almost all just simple two speaker audio systems. The other issue is that the "high-end" systems have now been so ridiculously oversold with respect to their performance that the actual physical equipment can't possibly live up to the hype. As I have put forward in some of my posts on this forum, the ultimate stereo recording/reproduction setup is a 32 bit float binaural live recording, replayed on quality headphones. If you want the kind of accuracy and realism touted by the "high-end" this is the only method to achieve that outcome.
As soon as you introduce the normal recording pipeline, the resultant audio is a synthesized assembly of sources, effects and processing and couldn't be further from a live recording. No matter how much money you spend, the elecronics and accessories in your stereo cannot put back what is missing. However, when you have a "reviewer" spouting a firehose torrent of superlatives and adjectives to describe a two-speaker sound system, you'd expect to stand (or sit) in front of such a system and be "blown away" with it's dynamic realism. Hoo boy, are you in for a dissapointment!
I'm not saying the reproduction of music from this gear is massively disappointing but it won't match the hyperbole generated by reviewers. I believe a two speaker sound system can reproduce something that sounds realistic but it would be totally dependent on the quality of the recording. I think Matt Hoopers experience shows that it's possible to produce something approaching realism with what I would call a "raw" live recording. This is not the case with studio recordings which have been the subject of manipulation and processing in the production process.
I am a musician first and some what of an audiophile whatever that means. I decided to go to my first Audiophile trade show (Axpona) to get a chance to listen to these
extravagant high end systems and listen to a few speakers I have been thinking about purchasing. I have to honestly say over all I was not blown away. I was expecting to be enlightened by some of these systems having speaker cables thicker than my arms, speakers with 20 drivers, Monoblocks on the floor raised up on titanium spikes basking in the glow of professional lighting systems and large glowing vacuum tubes. Some of these systems sounded really good yet not spectacular. I was anticipating walking into some of these rooms and hearing sound systems that would invoke a primal response in me like "wow I have never before heard such detail, clarity and an accurate sound stage like that ". Didn't happen. The speakers I specifically went to listen to, as I was considering purchasing, were underwhelming for the most part, making me question the glowing reviews I have watched on YouTube. So little focus on the music itself was also somewhat surprising. To me the higher end systems seemed more about image than sound.
After this experience there are two possibilities; The 3D detail and incredible life like clarity these super high end systems produce is above the sophistication and ability of my hearing to perceive, which is ok as I am going to save a lot of money or there is a lot of snake oil out there that I wasn't expecting?
There's also quite a bit of expectation bias in both directions. When I built my DIY I often compare with a ton of what I expect to be great hi-fi on many different exhibitions, but this can be very variable with regard to the different rooms, systems and philosophies behind each setup.
You are never going to have a real musical experience from a stereo system, even though you can get close and be happy, as long as you lower your expectations enough.
Also remember that your experience change greatly with hunger, tiredness and with written/spoken sales manipulation.
You might have done it wrong, to access the magic you have to listen attentively to the sales person, he will tell you what you will be hearing. Without his help it does not work.
Joke aside, the snake oil only works if you are enthusiastic about being bitten.
Every one should spend time at one of this freak show to clear any doubt about how much you need to spend to extract all the information from a recording.
