There is no need to ask, you just need to download his MDAT and look at the ETC to see a tonne of early and loud reflections.
Given questions on settings and such, I do prefer to wait to make sure all that is worked out before I look at any measurements. "First" measurement are often useless due to various things that happen at the start of the learning curve. You yourself suspect measurement error, right? So telling me to look at the data seems... premature.
My reason for suggesting what I did is that it can be done easily with skills already possessed. The multiple measurements seem reliable, if not valid.
Unreliable measures are worthless. Reliable measures, even if of low validity, can be used to look for differences. A bad survey won't tell you what a population thinks, but if it is reliable the changes over time (different measures) can have use value, enough to see if something is more or less popular at least. No way to tell how popular, but more or less, that works with a reliable survey.
In audio terms, I can use an uncalibrated mic to track differences in frequency response between measurements for many parts of the frequency response. Not with great precision, and certainly not full spectrum. But if I wanted to see how an EQ at 500hz performed, I could do it.
Not at 100hz, as I recall. Big mismatch on either side of that on the uncalibrated mic I used when I used it. Which was when I was trying to learn how to use REW, to see if it was something I was willing to pursue.
It was, and a calibrated mic was purchased shortly thereafter. Which is also when I learned just how MANY ways settings can be off.
