- Joined
- Mar 17, 2026
- Messages
- 101
- Likes
- 120
Anyone up to try my home brew speaker calibration system? Lol. It's closed source. I'm giving away a free licenses to every who will take time to help me beta test it. You need your speakers to be connected to a computer and right now the calibration files can only be loaded as a VST/AU/AAX. You will also need a cal mic. The algorithm that does the actual optimization took me over two years to perfect. I swear it's better than anything on the market. My inspiration for this project was basically "I think I can do better than this". It supports multi-subwoofer systems and will integrate the whole system for you automagically and there's nothing for you to set at all (almost). It looks at everything... time domain response, your distortion response, room modes, etc.
https://umamiaudio.com
If you're using MSO, give this a spin! Also for those asking, is DOES NOT try to maximize your bass SPL because that usually comes at the price of sound quality. It DOES make the response as linear and as tight and defined as possible at every seat while sacrificing as little volume as possible (because it also accounts for distortion). I'm here to answer any questions. Very open to questions and criticism. If you try it and find that it doesn't work well for your system I will personally have a look at your measurements and figure out exactly what went wrong and fix it for everyone.
