olds1959special
One of my four Kenwood L-05M’s made an extremely loud pop when I powered it down with the power button. Why did this happen? None of the other amps did that. I have been trying a new tube pre amp but I don’t see how that’s related? (I’m going to use the mute button on the preamp before turning on and off just in case, but not sure why that would make a difference) I turned it back on and off to test and everything works now, and fortunately music still plays as it should. I have old wiring in my house, and use three prong to two prong adaptors to plug in my power strip and small power conditioner. Any ideas what happened? Recently another amp I had, a Rotel, randomly popped and stopped working here. Not sure if there’s any relationship? My tube pre is buzzing slightly in the left channel, and I’ve had that issue before as well with a Rega Brio I once tried here. Right now I have all four amps plugged into a power strip, along with the preamp into the same strip, which is plugged into a small Furman power conditioner, which then goes to the 3 prong to 2 prong adapter and into the wall. I am turning all the gear on and off with their own power buttons, although for a few days I was using a power strip to turn on all the power amps at once, and also to power them down. I might go back to that for convenience. (I tried plugging everything into the same power strip to fix the buzzing but it didn’t help)
