concorde1
- Joined
- Mar 15, 2021
- Messages
- 447
- Likes
- 384
- Thread Starter
- #21
Hi again sigbergaudio (and all others)@concorde1 I would have a look at what I'm getting in-room in the listening room now before doing too much. Your nearfield measurement seems to have -6dB at 29hz and -10dB at 20hz already which is not too bad.
My interconnects finally arrived.
Here is my new Equalizer APO config (L and R are the 2 subs ; C and LFE are the 2 speakers) (Recall: using 8 channel Topping DM7 in 7.1 configuration)
Special trick in REW I figured out - might help someone! - I had to select "EXCL" version of Topping DAC in REW preferences, in order to access individual channels. When I wanted to measure ALL channels simultaneously, I had to select the "Topping DAC" option without EXCL and use L+R
Strangely, while the subs are about equidistant from my listening position, the right one apparently needed a significantly longer delay. (See config above)
Here's full system with all delays and full-range EQ applied (no bass boost though).
Note the 2x subs have a different volume control than the 2x speakers -- so I can turn the bass up further safely.
The subs are just placed without thought in front of each speaker.
Again, I did find it suspicious that the R sub needed much longer delay than L sub - maybe causing this 40Hz deficiency . . . ?
Any suggestions to improve freq response? Thanks.
