concorde1
- Joined
- Mar 15, 2021
- Messages
- 450
- Likes
- 385
Hi - I have just completed my 2x Scan-Speak Revelator subs, with completely custom 25mm HDF boxes.
Sealed and Passive.
They are powered by a Topping PA7 Plus power amp. Hopefully it will have enough juice.
As you can sort of see, they are coated in a pearlescent and metallic blue. Straight onto the (undercoated) HDF.
Final photo is each sub individually (the other turned off while it's being measured, of course), measured in REW at 5cm up to 500 Hz. (As per MiniDSP Linkwitz page recommendation.)
The best thing is, they worked first time, just like my DIY power amp did.
Also my amp build is in signature if you've not seen.
Questions welcome.
Also I'm unsure how to do a Linkwitz Transform without MiniDSP unit (I am using Topping DM7 multichannel DAC and Equalizer APO).
So if you can assist with integration please do!
I think Delay will be easy to correct, and I've already corrected my main speakers with Equalizer APO. I think I'll crossover the mains/subs at 70Hz.
I have to buy cables now to be able to use speakers and subs at same time so don't have a full spectrum measurement yet.
Sealed and Passive.
Questions welcome.
