Cypherdelic
- Joined
- Jul 22, 2025
- Messages
- 45
- Likes
- 8
Hi,
Im a little confused about coupling a subwoofer inbetween my stereo-front-standspeakers and how that affects SBIR and roommodes.
Gunter Nubert said, that two front subwoofers or two front standspeakers create a wavefront in which the waves join together and expand in the coupled direction (roomlength) only which leaves us basically left with only the frontwall and backwall to fix roommodes and SBIR with absorbers or using a DBA.
I dig deeper into that and found this explanation from QSC:
So it happens wavelength dependant.
Lets say my L/R-front-speakers have a distance of 3m.
For lower than half the wavelength 2*3m = 6m = 57hz.
So at this distance they couple only lower than 57hz.
My idea is now to place a subwoofer inbetween with a distance of around 1,5m to each standspeaker.
This should increase the mutual coupling into a wavefront of the front-bass to frequencies up 114hz, so making them louder and also killing a lot of roommodes.
Also problems with SBIR reflections reduce since each speaker is still at the same loudness, but the total loudness is +6db for coupling two. I dont know exactly what it means coupling three.
Lets think about it. +3db for the energy of the sub (doubling power), and then another +3db twice (per coupling of three) or triple? Idk thats +9 or +12db on the aligned wavefront, while the SBIR of one single of them to the next wall is just +0db. So with slightly different distances to frontwall and sidewall of the L/R and to frontwall with the S and a little bit of absorbers, even if they not thick enough and only absorb 30%, the SBIR is so low on single frequencies compared to the loudness of the wavefront that the nulling or peaking reduces to minimum.
Thats a pretty nice thing and theres no concert or festival not using the same kind of technology to couple PA-subwoofers.
I didn't knew that we can use this technology at home to reduce audio problems with the room.
In fact every stereo-speaker with bass-woofers feature that out of the box and usually you should place them in the stereotriangle, not 3m distance like me stupor, of course. Wirt 1m to 1,50m distance from speaker to speaker and from speaker to listening position you have a really high frequency coupling of the woofers.
Its interesting that you can "bridge" the gap on higher distance with subwoofer placed inbetween.
Thats awesome.
What does Subwoofers Mutual Coupling Mean - Blog | Resources
You will have noticed that in a large number of live events, sound engineers place subwoofers close together either on the floor, on the side of the stage, or at the top of the line-array rig. Are there any benefits in doing so, and what exactly happens? Before exploring the answer, let’s first...
blogs.qsc.com
Let’s now look at two different situations. First, if we setup two transducers next to each other at a distance of more than the half wavelength of the reproduced frequency, the average on- and off-axis measured output adds up to 3 dB (double the power). Now, with two transducers close enough to benefit from the mutual coupling effect, the measured output adds up to 6 dB.
Thats awesome.
