Musician Knight I (V2) Speaker Review
Rate this speaker:
    Votes: 92 49.2%
    Votes: 88 47.1%
    Votes: 7 3.7%
    Votes: 0 0.0%
This is a review and detailed measurements of the Musician Audio Knight I (V2) speaker. It was sent to me by Aoshida Audio and costs US $1,900 including shipping and "taxes." (for a pair)
The cabinet construction and look & feel is a step above any speaker I have tested. We are talking Birdseye maple finish with many coats of varnish rivaling and matching high end furniture! Not only that, it feels quite substantial and solid. It is a huge number of steps above any large production speaker of its kind.
While I have not heard of the brand before, it seems it is a very popular brand in China. They produce both electronics and speaker. Here are the specs:
The woofer is from Seas and soft dome tweeter has some 20 layers of fabric (from memory).
Musician Knight 1 V2 Speaker Measurements
Our anechoic frequency response unfortunately shows non-flat on axis response and directivity error:
Musician Audio Knight I V2 Speaker anechoic frequency response spionorama Measurements.png
It seems there is no baffle compensation. And due to lack of a waveguide, there is directivity mismatch between the woofer and tweeter. We see the impact of that in early window reflections:
Musician Audio Knight I V2 Speaker early window  frequency response spionorama Measurements.png
Resulting in a variable predicted in-room response:
Musician Audio Knight I V2 Speaker predicted in-room frequency response spionorama Measurements.png
Results will likely be very room dependent. Absorption of early reflections may do it some good although on axis response is still colored.
Near-field driver response shows a number of typical resonances and tweeter's uneven response:
Musician Audio Knight I V2 Speaker Backpanel driver and port Measurements.png
We can see those resonances in waterfall display as well:
Musician Audio Knight I V2 Speaker csd waterfall time domain Measurements.png
Directivity errors are quite a bit more visible in our specific plots:
Wider response, an "advantage" of lack of tweeter directivity control, will provide somewhat more spacious sound. But again, at the expense of more colorations.
Distortion is under control at 86 dBSPL but gets out of hand at 96 dBSPL:
Musician Audio Knight I V2 Speaker Backpanel THD distortion Measurements.png
Musician Audio Knight I V2 Speaker Backpanel relative THD distortion Measurements.png
We could accept the bass distortion but wish the tweeter was not there.
Zooming in bass:
Musician Audio Knight I V2 Speaker Low Frequency Distortion Limit SPL Measurements.png
If you are going to play very loud, best to cross it over pretty high with a subwoofer. On the other hand, if playing at low levels, it can go as deep as 40 Hz.
Impedance almost matches the spec:
Finally, step response looks rather clean:
I am still recovering from being sick. My ears are plugged so don't want to try to listen. I am sure you can imagine the colorations from the measurements.
Knight 1 (V2) brings impeccable aesthetics and construction to the table, justifying its cost. It is high-end furniture grade that should get positive reception from others in the households. Alas, it does not deliver technically. There are a lot of colorations. I hope the company works on a Version 3 to reduce these errors, and with it, provide a unique combination of good looks and performance.
Extremely basic speaker construction acoustically (seemingly no baffle step, no wave guide, classic 2-way directivity issues) doesn't justify the price. The finish may be of high quality, but that particular one is pretty ugly to my eye.
Amir,
Thank you for issuing the command to 'Release the Kraken, er Klippel' and may your ears unplug before you have to return these loudspeakers.....
Dear @AsciLab,
Consider whether you can source enclosures with wood veneers of a similar quality of finish as this loudspeaker :)
Yew wood can be finished in a near color as that of the speaker.
Dear @AsciLab,
It would be nice, but it would likely add another $1K to the price of the speaker.
That would be quite a surcharge over the standard finish.
I would be willing to consider it - for a 'custom' finish - to match my perception of the quality of their designs.
So, basically, take the aesthetic & engineering priorities of Ascilab and invert them.
Knight Audio: 75% looks, 25% sound
Ascilab: 25% looks, 75% sound
Also, being a bassist who’s owned a bird's eye maple bass and seen a million of ’em, that not only looks like a very cheap grade of the veneer, but they appear to have stained it a nasty shade of yellow.
Take a look at what Kiesel Guitars, Warmoth and Ibanez do to figured maple:
kieselguitars.com
warmoth.com
ibanez.com
Everything from natural to multiple dye finishes look stunning compared to this box.
I’m unimpressed.
Bruh, really? Com'on bro, you keep this up, I just might have to vote you as Time magazine' man with the most awful taste of the year award.
respect, those bevels and finish isn't one day job, maybe a week of work when considering 7+ coatings. too bad for some of the faults in sound design.
it looks like melting cheese, but me like :)
Zooming in bass:
Get well soon! I missed your reviews!!
So far the posts have been mostly about looks.
No problem with that, but I’d rather have an ugly speaker sound good than a pretty speaker that sounds like shite.
Just another pretty face, no substance. To bad. As a woodworker I can’t help but be impressed with the build….but as an ASR junkie…kind of bummed.
So! Amir! Thanks for the review and glad to have you back from AXPONA. Really appreciated your posts. “Almost” like being there without having to actually be in the Windy City. Thanks for taking one for the team. ; ) Lived there years ago, Not missing it.
Thanks for the testing Amir, a shame it wasn't a better performer.
Why did they make a speaker out of Swiss cheese?
I thought it looked interesting for a speaker cabinet, but sure reminded me of this Eocene Epoch Fossilised Insect Inclusions Specimen;
JSmith
