What does “Distortion @ 1kHz re 0 VU” mean?Actual tests of the very first generation machines in 1983:
Thank you for clarification. I would assume it would be -18/20 dBFS because 0 VU used to mean reference level as the VU metre also has plus values.0dBFS. The term wasn't even used back then.
Bear in mind, this is one of the first comprehensive reviews of several CD players in the entire world. Reviewers had to wait until they could get hold of test discs before they could assess anything.
I would argue that the low-level linearity is badly broken.Headless is a bit harsh IMO, it’s not terribly broken.
I'd like to learn more about how to interpret the likelihood transparency from the measurements. From this chart it seems to be the worst case is still transparent. But I'd like to learn.It is not audibly transparent. SINAD is at 1 kHz only. You can't use that to run with it and say across the board this DAC is transparent.
If you want to run with that anyway, there are 180 DACs that measure better than this across wide range of prices and features. In what version of universe landing at 180th position is anything acceptable?
CD format was created 40+ years ago. To barely approach its noise floor is simply unacceptable. What is worse is company enticing buyers by saying it is better than any other DAC specifically on measurements of distortion, noise and linearity. This product as I mentioned, needs to have been replaced with a better platform by now. There is no reason for me to recommend it at all and hence the headless panther. If technical specs is what they want to sell it on, then they need to build something that excels at that.
It still exceeds the resolution of a CD - can you hear the difference between -100 dB and -102 dB?I would argue that the low-level linearity is badly broken.
As @amirm asked, why would you accept a measurement just about better than a 40 year old technology? Wouldn’t you want something that satisfies the Hi-Res format that every music distributor have started to use?It still exceeds the resolution of a CD - can you hear the difference between -100 dB and -102 dB?
Maybe for you but not for me. Do please try not to patronise.What's there is enough.
Maybe we should have stayed using incandescent light bulbs. Those LED bulb manufacturers are making us to buy the light bulbs we already have.To make more money? To convince people to purchase music again? Because they need something to maintain sales? All of this and more?
I hope you realise that I was being sarcastic.Great argument, well done.
No, I never realized that, well done.I hope you realise that I was being sarcastic.
But, but, but, but....As @amirm asked, why would you accept a measurement just about better than a 40 year old technology? Wouldn’t you want something that satisfies the Hi-Res format that every music distributor have started to use?
If CD quality was enough why are the entire music industry are upgrading to Hi-Res?
So was he.I hope you realise that I was being sarcastic.
I keep seeing the comments referring that $9 apple dongle to so many other products in ASR.
Yeah, then the chassis alone, even if it was the ugliest kind available can simply go way beyond $9.Yes, it's just a silly comparison.
Can you input 2 optical Toslink fibre optic cables, 2 coaxial RCAs, a USB cable and get twin sets of balanced XLRs and RCA ouptputs in that $9 dongle? Nope.
