Hi All,
I'm a newbie here in regards to music sources so chasing some advice.
I've just finished building a high end 3 way floor stander, running off Hypex Fa253 Amps.
I'm setting this up solely for music and want to setup my source to be as high quality as practical for my application.
When I say that, I mean i know there is a DAC in the Hypex amps, but not sure how it all works depending on the input used into the Hypex. Is the dac
in the Hypex Always used? Or is that only when feeding it an analog signal? Whats generally accepted as the highest quality input to use?
As i say, complete noob here.
I've done a bit of reading on Wiim/Raspberry pi etc. Just not really sure which is ideal in my situation.
Ideally want a physical volume control on the unit if possible, and and happy to choose songs of my phone.
Any guidance would be great.
Thanks heaps
Thanks heaps
