wacomme
- Joined
- May 11, 2022
- Messages
- 428
- Likes
- 110
My work PC laptop (Windows 10) is heavily restricted, as is the internet access (though remarkably I can get Tidal). I've tried to get Equalizer APO to work on my PC laptop to no avail. Lately, I've been trying to get audio out to a Topping E30II dac. I also have a L50 that allows me the option of listening via headphones or external speakers (Audioengine A5's). I can load the dac driver, and within settings it looks like audio is playing through the Topping dac, but I get no sound. Within Device Manager, I get some access error (I forgot the error wording; I'm currently not at work, and I'm a Mac person at home). I don't want to inquire about the problem at work since the problem may be purposeful by administration - I'm not sure what the problem is - I'm not a PC person.
Ultimately, it would be good to bypass my whole work laptop. I can use my iPhone (cell service) + Apple Camera Adapter + Qudelix to listen to music via headphones or IEMs. While it works well, it ties up my iPhone making it unwieldy to use; I love the Qudelix for portable use, but I really don't like using it in my office. The same problem would apply connecting my iPhone to my Topping dac, sans any EQ I'd get with the Qudelix.
I thought I had a solution with a Raspberry Pi. I had a Pi 4 working running with Volumio, but the Pi started working intermittently and then wouldn't boot at all - this was from home. I pulled the Pi from the Raspberry 7" display housing, flashed a few SD micro discs with both Volumio and Moode software, but none of the flash drives would boot the software. My guess is that I have a broken Raspberry Pi - I have no idea how to fix it. Even if I could get the Raspberry working, I have my doubts I could connect it to my work network; my work network would recognize the Raspberry as a personal device, requiring a pop-up login - not sure how I'd be able to login with that required pop-up?
Another option is a Wiim - either mini or pro (could connect to work network via ethernet). Again, I'm not sure how the Wiim would handle the personal device login. I suppose I could buy a Wiim and see how it connects to my work network. Thoughts?
Is it possible to connect the Wiim to my iPhone used as a personal hotspot?
Is there another solution I'm overlooking?
