Music For Testing Bass
One of the organ recordings I have of over 300 is Peter Hurford's performance of Mendelssohn, one of the few that has 32' pipes recorded well though C0 isn't used, but D0 is at approximately 19Hz. The CD is also one of the few that is listenable straight through. A sample:
Ok, I'll look.... EMI Angel Records, A Bach Festival for Brass and Organ, The Empire Brass, Douglas Major on organ, recorded in Washington Cathedral. 1986.
Is it good? No idea.
Doing some quick reading, the acoustics are not great there, so likely not a great recording. It does have 64' pipe so can go very low, and there have been some renovations to the sound system, so maybe new recordings will be improved.
It does not have to be super deep, it just has to be there - rhythmic, engaging and fun.
Never knew Jeff Goldblum played the piano.... but he does. Then there's Haley Reinhart with her sultry voice and sweet charm. All with a lovely bass rhythm all the way through :D
The Washington Cathedral’s Skinner organ has a 64’ rank, but it doesn’t extend all the way down to the C, so they don’t actually have a 64’ pipe.
If you record (or listen) in the choir right behind the console, the sound is very good. It’s rather echoey out in the nave, with probably 5-6 seconds of RTA60. I learned that years ago occasionally attending the Sunday-afternoon organ recitals. That was back when David Majors was the organist and Sam Pilafian (RIP) in the Empire Brass wasn’t yet a friend. (I can never resist dropping Sam’s name—knowing him was a privilege.)
We were only ten rows back in the nave for a recent performance of the Mozart Requiem, and even that close it was muddy. But the Arvo Pärt Berliner Messe that led the program was suited to the church acoustics and it was transcendent.
Rick “the organ is currently being renovated and they are using an electronic substitute at present” Denney
Reactions: MAB
If you want to improve bass on subs, try a DBX 510.
510 Features​
  • Adds a signal an octave below the input signal
  • Two bands 24Hz-36Hz and 36Hz-56Hz
  • Subharmonic control over the strength of the effect
This device is very good. I recommend! It does need a bipolar PS +/- 15 v.
... or one could pick up any of dbx 120 variants. These are standalone 120VAC boxes that split the low bass up into four bands, centered at 28, 34, 40, and 50 Hz, and process each one individually. I rely on a 120X when playing my old classic rock albums and a 120X-ds for most everything else, simply because I'd rather not fiddle with the controls any more than absolutely necessary, and those genre require different settings. Also, the ds provides controls for fine tuning the operation within each individual band, which is great for acoustic music, but my old classic rock doesn't benefit from those.
I just came across this -
Shows what bass frequencies are being played.
All the bass from my SVS sb2000 Pro plays at the same loudness levels for all the tests (well - above 20Hz anyway :) )
The low A, 27.5 Hz, from the bowed down tuned double bass representing the Mississippi night, the drums creating the sounds surrounding the night and the guitar being Robert’s mind.
In case it hasn't been mentioned yet: "One for My Baby," Dianne Reeves. Just her voice and a double bass (for most of the track). Just wonderful.
Smetna Moldau any recording
Berlioz Requiem Dies Irae
Rachmaninov First symphony first movement
Dean Pear Lords Tundra
Janicek Requiem
Plus all of the previously noted Bach
My bass test playlist:
All can be found on spotify
Krumelur - beat straight down to 20hz
Classic, 1812 with canons and Very little kompression (Still miss my Telarc cd)
Infected Muhroom, not so much deep base but out of phase that with the beat Really hammers our ears in a strange way (stereo / out of phase bass)
Infected usually have a clean bass beat, Nigel Stanford is a bit more rumbling sounding.
