Music App on MacOS 27 and iOS 27 finally plays bit perfect
stefanovesa
Italy
I've just downloaded MacOS 27 (Golden Gate) and iOS 27. I'm happy to share that finally Apple has fixed how Music App manages local audio files. Finally the bits are not tainted and the player works bit perfect for 16 and 24 bits at all the SR supported by the DAC. I've tested with RME ADI-2 DAC FS bit perfect check files. 32 bit files are still not supported because the CoreAudio format used by Music is 32 bit FLOAT. FLAC files still not supported (expected). In MacOS the SR change must still be done manually according to the source file, in iOS is automatic, as in previous versions.
I hope that Apple will not incur in any future regression...
Good news, and it matches what Apple changed: Music now passes integer PCM without the old float conversion. Worth adding: bit-perfect still needs the volume at 100% (or integer-step volume) and no EQ/Sound Check, and the app has to switch the device sample rate or CoreAudio resamples. The 32-bit limitation is exactly the float path, so >24-bit files fall back.
Is there a forum rule against copy pasted llm slop?
Does macOS now finally auto switch sample rates?
not in MacOS, true only for iOS. Anyway, from MacOS 26 ongoing, no need to restart anymore Music when the SR is manually changed in the MIDI console.
correct
I know nothing about Macs, and I'm not averse to one bar the price, but are you all saying there is no equivalent to WASAPI exclusive mode for media players to use? I've been using that for my FLACs with Foobar2000 for... I can't remember how long.
And for me the PC is only for casual listening at my desk with a Topping DX1 of late. If I use my main stereo in the lounge, I use DLNA on the PC, but only if my NAS is turned off (if on, then I point my streamer at the DLNA server on that NAS instead, and either way, always bit-perfect).
The long story short is that if a PC or Mac is playing music to an amp/speakers or headphones, it's probably overkill worrying about bit depths & sample rate conversions and so on, as these things are done pretty well these days, and on my PC, sure, the bit-perfect setup is probably overkill, but it is just an easy default to use. I probably would not notice any sonic benefit by not going through extra windows junk, but with the new Mac changes is it obvious?
@Redacted yes, macOS has one. Core Audio calls it hog mode: one app takes exclusive ownership of the output device, and system sounds and other apps can't play through it until it lets go. It's the counterpart to WASAPI exclusive. Music doesn't use it; several third-party players do.
Related to the question about auto-switching: macOS never changes the sample rate on its own. The playing app has to set the device's rate. Music does that on iOS but still not on macOS, hence the trip to Audio MIDI Setup, and if the device is left at 48 kHz when you play a 44.1 file, it gets resampled without telling you. And Core Audio hands the driver 32-bit float, which carries 16- and 24-bit samples exactly but can't carry 32-bit integer, which is why the 32-bit files fail the bit test.
Will you hear any of it? No. If the rate matches and nothing touches the samples, the output is identical. Exclusive mode and automatic rate switching exist to make sure that really is the case: no silent resample because the device was left at 48 kHz, and no notification sound mixed into the stream.
(Disclosure: I make Fidelia, which does both on the Mac, so I've spent more time in Core Audio's plumbing than is healthy.)
Interesting info!
LosslessSwitcher is still a thing, and the v2 beta works well on my Macs. Saves fiddling around with Audio Midi settings.
Check out Fidelia if you want a tailored UI for all of the above, then you can also stream your whole library to the iPhone, CarPlay, etc. happy to hear your thoughts:
cheers all,
Patrick
cheers all,
Patrick
This is a great product! Nice UI, great integration with Lyrion, easy to configure. Hoping you guys will have a Black Friday sale!
