Musetec Audio (LKS Audio) MH-DA005 Review (DAC)
Rate this DAC:
    Votes: 202 82.8%
    Votes: 26 10.7%
  • 3. Fine (happy panther
    Votes: 4 1.6%
    Votes: 12 4.9%
Turcoda
Thanks for measuring this. I will state that I owned this product for 1 month in total before I returned it. Yes it sounded good, but it is not worth $3k. In fact, when I went back to my D1Se (700$), I barely noticed a difference. I actually prefer the midrange of the D1se. Its possible I have potato ears and that my unit was a 1 off defective unit, but overall I was NOT impressed.
Why did I return it? It had a million and one problems with the USB implementation. I'm not sure if they messed something up with the Amanero board or something software/firmware related is getting in the way, but it kept messing up and required multiple reboots per day. After a while of being turned on it would accumulate large amounts of lag/delay and made playing games unbearable. I'd also frequently hear artifacts after having it powered on for a while. I also tried the VMV D2, which i think is probably not far quality wise than this. I returned it for being overly smooth. My next DAC is going to be the Dac3.
I don't care to be judged for having cheap taste. I'm always auditioning stuff and I have a special place in my heart for things that measure amazingly well, as well as for things that just sound amazing overall. Sadly this is neither. Last month I sold my 4k$ Raal amp to buy an 800$ schiit amp and I'm much happier with the choice. I barely hear a difference. I'm a reformed money-flushing audiophile. I now firmly believe more money doesn't always get you better. This is one of those cases.
Billy Budapest
I think there's a lot of psychology in this. As long as megabucks gear exists, supported by subjective reviews, there's a reluctance to accept that anything costing a tiny fraction of that can really be that good, no matter what the measurements say. Some think that there's also an "impress your mates" factor too, but just how many audiophiles have audiophile mates to impress (mates who aren't audiophiles won't even notice; it's not like flash cars, or certain watch brands, where everyone knows what they are)?
doitttt
mustec must, in the toolbox again, and make something that works, lks0005 mk2
when looking at reviews if taking msb dac which costs 90000dollars
the magazines that test are, with highend equipment
from laptop, to good dac, with flac files, so not much difference
the msb dac or good dac
Musec
This is a review and detailed measurements of the Musetec Audio (LKS Audio) MH-DA005 ES9038 based stereo DAC. It was kindly purchased new and drop shipped to me. It costs US $3,299.
At 12 Kg/26 pounds, this is one of the heaviest DACs I have tested. Fit and finish is excellent as you can see in the above picture. That carries to the chunky metal remote:
When I plugged the unit in, Windows did not load the class driver for it which means it is not class compliant. I could not find a driver online but a flash drive as shown above comes with an ASIO driver. The internal USB interface is the common but old Amanero. Driver installed but the ASIO driver would not function. The remote was not functional either. I saw a screw driver in the box which I assume is to open its back to put in batteries. What a pain.
When I powered the unit, it started to count down tell me to wait! I glanced at the main board and it seems to have a bunch of supercaps or batteries in that that it must be charging. Anyway, I waited the two minutes for it to get ready.
Musetec MH-DA005 Measurements
I couldn't believe these results. Company spec is 10x lower distortion:
I changed inputs and measured RCA output:
Going with this, performance is unacceptable at any price level these days let alone wht MH-DA005 costs:
I suspected the output stage may be saturating so ran a sweep:
That is it. We are now very close to rated spec (110 dB vs 114 dB spec) but we can only get there at 1.5 volt output. This is bad.
News gets worse with IMD two-tones:
So we not only have output saturation we saw before, but mother of all "ESS DAC IMD hump!" At lower outputs performance drops to that of a $9 phone dongle!
Not all news is bad. Dynamic range for example is excellent:
Linearity is perfect:
Just when you settle in, here comes the jitter test:
There is a DPLL bandwidth setting but that could help internally generated noise sources above. But even if they do, none of the settings should be this bad.
Without the remote working, I could not change filters. Fortunately the default one is what you expect:
Multitone test shows rising distortion with frequency which is again disappointing:
This in turn shows up in THD+N vs frequency:
So easy to fall in the trap of going by looks, price and written specs (as opposed to proper measurements). While doing a few things right, there is a lot wrong with design of MH-DA005. They have an excellent core as far as DAC chip is concerned, but they poorly implement the companion circuits. Instead of focusing to get the basics right, focus seems to be elsewhere (battery bank and such). A shame since the packaging is very nice.
I cannot recommend the Musetec Audio (LKS Audio) MH-DA005. If someone thinks this sample is broken, then get the company to produce the above measurements and I will happy to revisit.
I have been listening to this DAC for over a year with great pleasure. Clearly a class better than its predecessor LKS MH-DA003 and it easily beat more expensive DACs that I've listened to in recent years. Provided this test sample has manufacturing defects, I highly doubt the measurements. The integrity of this DAC is unprecedented what anyone can experience at my home. It is in any case a good lesson that you can not go blind on these measurements and just listen to a DAC at home for a few weeks .
Purité Audio
Industry Insider
Barrowmaster
London
Now that you have discovered what a valuable resource ASR is, you can choose your next dac on facilities and measurement and never again feel the need to apologise for it.
Turcoda
When i switched back to my D1se after having used the 005 for a month, I didn't notice any appreciable differences. The 005 was slightly smoother, but that's all that I recall. I think at first I suspected the soundstage was a tad larger, but I think I imagined it. I don't think I'm missing anything by using the D1se right now. I don't think the 005 is worth 4-5x the price of the D1se. One thing that wasn't mentioned was that even though both the 005 and D1se have an output of 4.0 vrms, the max volume of the 005 setting (0.0db) was quite a bit louder than the max volume of the D1se (level 99). I suspect something weird voodoo magic is happening with that. Everyone should take care to properly volume match when doing A/B comparisons.
muslhead
snark warning.
Another poorly measured device that deniers blame on it being a bad sample. Couldnt be anything else of course.
I have never seen such luck before. If we could bottle ASR's luck of drawing bad samples and go to Vegas .... we all could be gazillionaires.
All that statistics i took in college have been disproven. I am in awe.
Deaf
I have never been able to hear a test measurement and I will never buy something based only on someone's test measurements. Listening to any component is the ONLY way to know how it sounds. As for burn in, it makes a difference to me, as I have proved on over 100 pieces of gear over the years. I have had inexpensive gear that sounded better than high price stuff and I have heard a couple of million, yes million, dollar systems, one owned by a Dagogo reviewer, but I would never think that a piece for $100 is SOTA. Remember, not one of us owns a system that is exactly the same, room included, as any one else does, so every system sound different.
tw99
West Berkshire, UK
Let me guess, you own one of these ?
Lupin
Crazy how this is so expensive with such poor overall performance... I don't get what companies are doing these days thinking they can get away with this stuff..
They don't think.. they ARE getting away with it. (sadly)
Mainly due subjectivists on places like Head-Fi who make each other crazy with all kind off ridiculous statements and influence newcomers into the audiophile scene to think/do the same thing.
MacCali
Dude.. he has EARS
The ears are fairly deceptive, not talking about this specific product. It’s not a form of deception, it’s merely what you have heard all of your life. Especially prior to joining ASR or maybe stereophiles measurements you had no clue what you were listening to. Also can’t always depend on manufacturer specs.
I fully believe in measurements but can consistently see that even extremely well measuring products don’t sound good, yet some sound amazing which would seem odd. Shouldn’t they all be great? I think the answer may lay in the presentation.
Also as stated by Amir, the dac 100% needs top notch performance. He gave rough estimates of what needs to be good or more which needs to be as close to state of the art and what you can get away with
In addition, at least when it comes to an amplifier, I have and still listen to an amp which measures less than -40 db and I have an amp which measures in the low to high 90’s at low volume with everything connected to this amp state of art and recommended by Amir and subjectively the crap amp doesn’t sound bad in comparison.
No way am I saying that the poorly measuring amps or equipment are better or can even match state of the art. Just simply that it’s not as bad as you would assume. Also couldn’t provide a definitive answer to how much worse or how much better a state of the art amp is
This is also why I feel a lot of manufacturers have got away selling high end priced crap with mid grade measurements cause if the worst isn’t that bad you should be able to understand that something with a sinad of -80 would sound good to a lot of people.
So this creates an understanding why someone would say that this piece of equipment sounds good when it measures mediocre and also a way for a subjective person to attack the objective point. The difference between 80 and 100 db sinad on an amp is even much less noticeable, even though clearly there is one. It goes both ways
Back to my previous comment distortion noise etc has always been present in everything you have always listened to before objectivity became prevalent.
respice finem
Because, still more often than not, they do get away, alas.
Not everybody reads reviews on ASR and similar sites. But it's generally slowly getting better.
CleanSound
Northeastern region of USA
I want to thank @amirm for the work you do by sharing a story.
I purchased a LKS MH-DA004 almost 3 years ago, it is the little brother to the MH-DA005 in this review.
From their website (see screenshot below), the specs looks great, the color and form factors meets my taste. The case work is luxurious, the parts used and internal circuit layout is higher end than DACs many times it's price.
This is during the time that Topping, SMSL, Matrix, Gustard and the likes are destroying the competition (I mean DESTROYING the competition, where the gap between first and second place is miles apart) and are objectively and independently verified of their published specs, not only by ASR but by other channels as well.
Surely LKS, their competitor and compatriot would be in a similar predicament, they surely would published legitimate and honest specs, particularly there are now "trouble makers" out there going around with a $30k AP measuring shit. After all, it would be just too ballsy and a reputational suicide to falsified and lie about your specs in the competitive space you're in. This competitive space being the New World Order of affordable and unimaginable performance of Chinese Hi-Fi (I was going to use the C word as a term of endearment, but it's understandably banned on this forum) that has left the rest of the industry desperately scrambling for an answer.
So I gave it no second guess on LKS' business integrity, manufacturer/consumer trust and on the basic principles or morality and make the purchase from Apos on sale for $1,359 (normally $1,500).
When it came in the mail, I was giddy like a schoolchild as I unboxed it. Damn, this thing is luxury, 20 lbs of luxury. Touching and petting it gives me tactile euphoria. Now, I am not a complete sucker, I know I (nor any other human being) won't be able to discern the difference between the published spec of .0003% vs other lesser performing DAC of say .03%, but regardless, the engineering marvel gives me goosebumps and having it as part of my system gives me a peace of mind and pride of ownership.
Oddly, couple of months later, Apos stop carrying LKS altogether, while their competition still are. I will circle back on this later.
Then almost two years later, ASR drops this review and measurement of the MH-DA005. My heart sunk. I was devastated, I was devastated because I was cheated. You see, I grew up in the hustling streets of NYC, I hustle others, rarely do others hustle me. . .and now my pride is broken and my butt hurts. Sure, this is a measurement for the 005, not the 004. But let's be honest with ourselves, do you really from the bottom of your heart think there is even a remote possibility that the 004 will be measured as they are spec'ed by LKS? Fool me twice and I deserved every bit of it.
Now, why did Apos stop carrying LKS? I suspect, it is possible that they found something fishy about LKS and Apos did not want to damage their own reputation or deal with customer returns should a third party verify the specs.
I finally parted ways with this LKS responsibly and with integrity at the start of the summer. And I also let my sorrows part with it.
As a thank you @amirm I will be making a forum donation (anonymously, this is the internet after all and privacy is utmost important).
Mart68
England
Cheer up, I see I gave it a 'Not terrible' and five people voted 'Golfing'.
Turcoda
LKS is the reason i stopped giving into "hjigh end audio" snake oil BS predatory practices. I owned the 005 for roughly a month and had nothing but problems with it. I still swear to his day old old SMSM (VMV D1Se) sounded superior. The 005 was overly smooth and not as crisp as that one. If you have a pairing of devices that are overly analytical, then i suspect you'll find the 005 sounds good. The thing is, it s not going to add value to your audio chain - it'll just give you a different flavoring. MIND YOU, I owned topping and smsl devices before and I must urge you to carefully weigh what your ears hear vs what your eyes see in the data. The topping stuff i've owned s crisp and clean, but could sound thin and lackluster at times. I literally stopped enjoying music at times with certain devices that were known to measure superbly well. Criticize me all you want, but my personal experience is that specs do not capture everything. Im a stickler for detail, but when audio sounds overly thin and notes sound overly airy or spaced out, I find i lose a lot of auditory experience. With that said, I've had decent luck with Schiit and Mytek offerings as well. Don't rule out the North American gear as well!
CleanSound
It's meant to be an dramatized story. I am ok and I no longer have it. . .waiting for Gustard to drop their next flagship ESS DAC, after it's measured by Amir of course or I might be the one to send him the unit to measure and let the data help me decide if I keep it or return it.
