staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,849
- Likes
- 28,308
Logically, the answer is DSP Plate amps with Digital in, like those from Hypex, Platin, Wondom, Arylic.That is, as I see it, the best way to do it. DSP/Equalizer feeding the power amps with short cables and long thick cables passively from the power amps.
My question is how you best mage that with the smaller class D amp, each with its own supply, handling a subwoofer or two. Chinese audio has not yet devised a way to do it for high end projects using their small amps.
I come from the times when passive and active crossovers were discussed between more critical audiophiles. The problem was the expensive power amps that you had to use. Now the amps are cheaper. It should be a time to discuss an implementation like the one I explained.
That way, there are no low-level cables and the speaker cables are kept as short as possible.
