Hello, I'm new, and I was recommended to come to this forum to see if you can help me with this topic.
I have a pc, to which I would like to connect 4 iems, either to watch movies, listen to music and play games.
The iems that I would buy (4 in total) are: the moondrop blessing 2 dusk.
whose impedance is 22.
According to what they told me, I should use a dac to connect them to the pc and then use a splitter for each iem.
As they are iem, and they have a very low impedance, I had to search a lot until I found a dac that works for them.
The topping dx7 pro +.
Therefore, things would remain this way.
PC - - - - - dac (topping dx7 pro +) - - - - - splitter - - - - - iem x4.
My query is:
1- Is this possible, how is it proposed or do we have to add more things.
2-I will achieve that all the iem can be heard well, without noise or distortion.
3-with this configuration there is no danger for the dac, example overload, etc.
4 - will be achieved with this configuration, play the best audio codecs available in the dac topping.
Thank you so much.
My query is:
Thank you so much.
