Multichannel audio on a Pi will get a whole lot easier and cheaper!
which DA converter would you use for a 100% active speaker home cinema with 42 channel ? :) the smls su2 is not really an option for that amount
Once you go over 32 analog ports per host PC, you need to either go up to AoIP LAN-based professional level gear (MOTU AVB protocol with their special ethernet switch is relatively affordable compared to say Dante gear)
or use primary interfacii coupled with multiple expansion converter rack units, say 16/24/32 ports per - ADAT ports are 8x each, and that's only at lower frequency rates. MADI is in between...
The challenge is tying all of the secondary actual A/D D/A converters together via a single master clock - BNC Word Clock being best. The underlying primary interfacii can be left as "sync via digital signal".
Some converters need to be "Master only" - can create conflicts, ones with ability to switch to Slave mode give more flexibility.
We don't need to discus that 42 Channels would become very expensive anyway, so there are some possibilitys to do so depends on what kind of Connection you could use.
on the cheeper side:
Ferrofish Pulse16 AE 16Channel 990€
Ferrofish A32 Pro Dante MM 32Channel 3600€
more expensive side:
HAPI mk3 16 Channel 2700€ + 2x 1200€ Standart DAC Cards
You can sync them all with let say this 1099$ but also cheeper option aviable:
https://blacklionaudio.com/en/products/revolution-clock-xc
Jitter 0.5 pS RMS on BNC Out!!!
But you could also use the First Device as Master and feed Wordclock to the next Device. All here listed Devices have Wordclock In and Out.
ADAT Inputs:
So let say 3x Ferrofish 16AE (48Channel IO) 3000€ + Clock = around 4100€
ADAT or DANTE inputs:
2x Ferrofish A32 Pro Dante MM (64 Channels IO) 7200€ + Clock = 8300€
Dante or AES inputs:
3x HAPI mk3 5100€ (48 Channels only Outs) 15300€ + Clock = 16400€
But there some more Studio like options.
Most have DANTE or / and ADAT some DANTE and AES
RME M-1620 Pro 16 Channels IO 2869€ DANTE, ADAT and MADI
RME M-32 DA Pro II-D 32Channels In or Out 3789€ Dante and MADI only!
But 48 Channel /2 = 24 DAC'S * 99€ around 2400 to 2500€ still the cheepest option LOOOOOL
3x RME HDSPe AES = 48 Channels = 3x 850€ = 2550€
1PC around 800 to 1000€
If you wan't to use DANTE only then use RME HDSPe AOX-D 1800€ PCIe 4X Card
up to 512 Channels in and Out 256x256
Let say Hyperion DPR-16 with Dante Out to RME HDSPe AOX-D to 3x RME M-1620 Pro
4000€ + 1800€ + 3 x 2869€ + 1000€ PC = 15047€
But i need to ask what kind of Surround Setup it is, that you need 42 Chanels ??? or all Speaker are 3 Way or a lot of Subwoofer used ??
sure it is comparable expensive - but still cheaper than buying ****** dsp amps for PA purpose. i built 40 channel hypex ncx500 with microaudio smps, so i am not using behringer DA stuff etc.
9 bed layer 3-way speaker and i am not done with decision on atmos ... 4 2-way or 4x 3way .. but i tend due to size to 2-way -> 35 channel for the speaker. for subwoofer i have 2x 28" Ascendo and 1x 32" ascendo for infra, therefore only 3 channel for subs. i will replace the speaker in the picture. base absorption are tuned HH resonator .. 2 tons of wood in the front and back, 60cm deep front and back "wall".
currently i am negotiationg a Antelope Galaxy 64 core .. maybe around 6k. That would be my prefered way to go.
Yeah lots off chassis to setup ;)
https://www.thomann.de/de/antelope_galaxy_64_synergy_core.htm
8900€ in Germany for now.
But if you are using DANTE is probably the best way to go, it's an pitty that this Devices also have many Inputs you don't need.
And i use also HYPEX OEM Amp Modules NC122 and NC250, didn't have an own House so can't listen realy Loud ;)
yeah, i am selling my altitude 32 if the hyperion dpr-16 holds what it promise .. german here as well ;)
I look at this DPR-16 also already, i hope it is possible to play at minimum 96kHz on AES Outs, than i will buy it too ;)
Till than i have to use my DYI HDMI to 4x AES Extractor (LPCM only) i guess.
most likely not, would be odd.
Immersive decoding (like Dolby Atmos or DTS:X) is natively mastered at 48kHz .. i will upsample in the camilladsp where it makes sense and network standard is 48khz as well, dante and aes67
Yeah but i have HD Master audio recordings with 192kHz , DVD Audios with 96kz and that why i need at least 96kHz, Camilla runs at 96kHz, so it would be enough, or you get to long Delays on FIR Filter and lots off Processingpower needed specialy on more than 16 Channels ;)
DANTE or ASE67 is for my confusing, sometimes DANTE gives higher Samplingrate sometimes ASE67, but sure higher Samplerate less Channels aviable and ATMOS has only 48kHz.
But i didn't have much Dolby Atmos Music at all for now may be on some Blueray Films i have it.
I have also SACD's played as PCM OUT on my Cambridgeaudio Blueray player CXU.
My Project in progress is here:
https://www.diyaudio.com/community/...or-full-surround-digital-aktive-setup.440807/
But for now i need to make an short Break on that and move my Stuff into an new Apartment till midth off Juli :(
Also my CNC Machine need to move and thats a bit tricky as well, still need it to build my Amp enclousures for my Hapex Modules.......amd my new main Speaker LOL
Some Time is gone and i was able to do some Measurings on my Setup reaching THD+N around -122dB without any visable Jitter artifacts feeding from HDMI ;)
https://www.diyaudio.com/community/...ound-digital-aktive-setup.440807/post-8411995
What more i need ....ah Yes ATMOS in the Future ;) (16 Channel in 32 Channel Out with 2x RME HDSPe AES)
Of course is off topic has nothing to do with an PI anymorer :( But i will test this REM Card also on an PI in the Future with an PCI x1 Extender Board if i got Time to do so.
