Multichannel and immersive music: a new graphical representation of spatial sound
Jean.Francois
Hello,
The goal of Magicvinyldigital.net is to provide album reviews across all formats, including immersive audio, based on both listening and technical measurements. Since March 2022, in order to better understand the spatialization of immersive albums, from 4.0 up to Dolby Atmos 9.1.6, a spatialization graph has been added to multichannel versions to better visualize how sound is distributed.
After four years of implementation, the spatialization score (SP) provides a solid indication of how different audio channels are utilized. It is based on an evaluation of sound level distribution across these channels, as defined when this representation was first introduced.
SP mode : Tears For Fears – Shout
However, after analyzing more than a hundred immersive albums, it became clear that one element was missing: a parameter capable of representing the dynamic aspect of spatialization and its movement through space, in addition to the existing data.
To address this, a new graph will be introduced to represent:
  • The variation of spatialization over time, including potential sound movements in space
  • The relative position of sound in space (for example, identical sound across all channels is perceived as centered)
  • The movement and occupation of 3D space, helping to characterize how the mix uses the available sound field
These elements will make it possible to define a new score, complementing the existing one, to better describe these aspects.
As always, this score is an indicator of Spatial Kinetics (SK), not a measure of its quality. It reflects how dynamically the sound space is used. An immersive mix can therefore be excellent even if it does not achieve the highest score.
This new evaluation is based on a 9.1.6 reference configuration rather than the more commonly used 7.1.4. While the format may eventually evolve toward 22.2, no music content is currently available in that format.
This approach allows Dolby Atmos mixes to be represented in 9.1.6 while supporting all existing formats (7.1.4, 5.1.2, 5.1, 5.0, 4.0), including stereo.
To best represent spatialization, the graph offers a three-dimensional visualization with four available views:
  • A top view, showing channel levels similar to the previous model, enhanced with a color gradient from dark blue to white to represent frequencies from low to high
  • Side and rear views, allowing analysis of front/back distribution and height usage (including top channels)
  • A full 3D view, providing a comprehensive spatial representation
Some examples of the new graph :
Propaganda – Dream Within A Dream (5.1 SACD)
The track Dream Within A Dream in 5.1 is a great example of a mix that fully exploits spatialization within a 5.1 setup, with circular movements forming a star-like pattern with multiple branches corresponding to the positions of the sounds. It can also be noted that there is no height information, as none was present in the original source. It can be observed that using the entire space, even without height, allows for an SK of 5.9 (without rendering in the rear surround channel), while the SP, which represents channel usage, is at 3.1 due to the limitation to a reduced number of channels.
David-Gilmour-01-5-A.M.-Live-from-the-Luck-and-Strange-Concerts_Spatial6.85.9_DR11_3D_quad-1.png
David Gilmour – 5 A.M.
The track 5 A.M. by David Gilmour, presented here decoded in 7.1.4, delivers a similar SK (5.9) to the Propaganda track in 5.1, but with a 3D distribution. The sound is less spread across the horizontal plane, but makes greater use of the height channels, adding more volume to the overall spatial representation. The SP value of 6.8 shows a good distribution between the front and rear channels, but with a mix that does not fully utilize the entire sound space in Atmos.
Find more examples of 3D analyses, a real-time 3D visualisation and further details on how it works here (MagicVinylDigital.net)
Enjoy listening,
Jean-François
Hello,
This video features an improved version of the spatial representation of sound. A color variation has been added based on the height of the sound: sounds that remain at the level of the main speakers appear in blue, while their color gradually shifts toward red as they rise. This makes it easier to visualize the elevation of sound within the room.
Enjoy listening,
Jean-François
