Yes, I've watched your and videos from other people on the subject. I just re-watched it again. Thank you very much for great video!If you haven't done so, have a look at the MSO 2.0 tutorial video linked in my sig below.
Yes, that part makes sense, thank you. I have delay in cm, so maximum is 999cm which is around 29ms.If you are only looking to time align the subs using MSO, the just use the "Maximize SPL using only delays and all-pass filters" Optimization Type, setting the delay range to the max range you have available in your AVR and not using the All-pass filter option.
Thanks for this, I was really puzzled on what is the best way to approach it.For sub gain settings, set them at a high setting (say 80% to 100% of max) on rotary dials on the subs themselves prior to doing your raw measurements and leave them at these settings permanently (it's handy to mark the setting on a piece of masking tape beside the dial in case you accidentally change them later) and AVR volume such that your raw measurement sweeps have max peaks of around 90-100dB SPL in the 30-60Hz range. This is a decent sweet spot between testing subs near but not approaching their upper limit and well above the noise floor.
So I have few of questions here:Use the AVR amp sub gain setting after MSO to balance the subs and the mains but do not adjust the rotary dials on the subs.
1. How do I match levels correctly to mains? Just using SPL? Or running a full sweep in REW and adjusting gain equally on both? Or there is a better way?
2. Your video explains how to match subs between each other, but what is the best way to match delay to mains? There will be sub amplifier delay, even on a wired sub, delay can might be significant.
3. Is there a way to find best crossover point in MSO?
Thanks, yes i spoke to Lyngdorf and they say they do not override PEQs which are set manually.You can optionally use the "Shared Filters" in MSO for the 8 PEQ spots you have in the Lyngdorf as long as the room perfect correction does not override these during its processing.
