Multi channel music with active digital speakers
Purité Audio
Industry Insider
Barrowmaster
London
I would like to set up a multi channel system using digital active monitors, the speakers have dac/ad built in, what do I need?
Thanks in advance,
Kal Rubinson
Industry Insider
NYC
They have their own DACs. What is your source and can it supply multiple digital outputs, one per channel?
q3cpma
France
Using digital or analogue input? Should be complicated (as Genelec's 9301A shows) as AES is for stereo signals.
EDIT: MiniDSP's U-DIO8 is probably the only reasonable answer, even if absolute performance is disappointing. There's also RME's Digiface with 4x optical out and HDSPe AES PCIe card for 8x AES.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Kal I use Roon Nucleus/software for 2 channel, I guess I need a box that can , implement the correct codec?
Thanks Keith
simple6
London, UK
There are a few threads on this subject in different parts of the internet. The best solution would be an AV processor with digital out signal per channel. Altitude 32 (and a few other processors) do it but not for cheap. There is a hope that Trinnov may release a digital only multichannel processor in the near future but haven’t seen any hard proof yet.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Is the audio equivalent of Atmos ( what is the audio equivalent of Atmos) only available incorporated into an AV prepro?
You use the Okto 8-channel don’t you Kal?
mkt
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Yes that MiniDSp unit would work, but I need the bit that splits the signal into left ,right centre, etc.
What is the difference part from price between the Trinnov ‘Altitude’ and. prepro AV from say Denon/Marantz?
Kal Rubinson
Industry Insider
NYC
Yes, but Atmos is irrelevant for music.
I do but it is a multichannel DAC. If you use the analog inputs of your speakers it will run off any MCH server, e.g., running Roon or Jriver.
Yes, the U-dio8 would run up to 8 channels via AES/EBU or via S/PDIF.
Won't the digital input circuitry of the speakers do the splitting of the pairs? They do it in stereo.
Multiples. The Storm Audio prepro would be ideal but it, too, is pricey $$$$$$............oops, ££££!
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
If I select a multi-channel recording from Quboz, into the MiniDSP U-D108 then on into the speakers,( I can select left and right from their app ) will ROON sort out the main and injection channels?
Thanks everyone, I apologise for the dumb questions.
mkt
This is genelec way. Daisy chained.
Dimifoot
Greece
mkt
Seems like it, but your use case might be a little different?
EDIT. A relevant item under "Device setup"
Kal Rubinson
Industry Insider
NYC
I do not know what an injection channel is. The main channels are L, R, C, Sub, Ls, Rs. The U-DIO8 will output the following pairs (L, R), (C, Sub), (Ls, Rs) and, if needed, (Lr, Rr). You can change them all around but there's usually no need to.
LightninBoy
St. Paul, MN
Thanks in advance,
I don't know the answer, but I believe this is the way forward for the best sound - digital all the way to the speaker. Just wish there was a couple manufacturers stepping up and making it easier for at least the enthusiast to adopt.
Reactions: mkt
Dimifoot
Greece
Multichannel Roon Ethernet streaming+
Digital outs+
Immersive Music (Auro3d/Atmos)
Trinnov Altitude 32
pomfritz
Hello here, after numerous searches I came across this thread. I have the exact same problem and it's hard to understand for a simple user. What's the impact of feeding separate DACs from a single source (RME Audio HDSP AES 32) trough SPDIF? Since years, I do it on my Musical Fidelity M1DACs with no audible issues. I hear so many warnings of drift between DACs, that I'm afraid to buy anything else. I'm not interested in multi-channels DACs and World Clock synced DACs are too expensive. Does PLL be taken into account when talking about such a configuration?
