flyingflatfour
- Joined
- May 3, 2020
- Messages
- 52
- Likes
- 2
Does this happen even if you convert DSD to PCM with Roon?
There is a one-to-one correlation of the two (at least to begin with).
Yes. Actually I have only tried it like that.Does this happen even if you convert DSD to PCM with Roon?
Using the Oppo?How does one setup bass management to redirect bass frequencies to a subwoofer with a 5.0 or 2.0 signal? Confused
Connect Roon to the Oppo with HDMI.MacBook running Roon -Ethernet-Oppo203 as Roon Ready device-connected by HDMI-to Trinnov
When streaming multichannel I get 2 channels out from the Oppo.
If Trinnov is used as a Roon Ready device, then there is no problem with multichannel
EZ. Set Roon to 5.1 output and add procedural filters to (1) route the main channels to sum in the LFE channel, (2) add a LP filter to the LFE channel and (3) addHP filters on the main channels.How does one setup bass management to redirect bass frequencies to a subwoofer with a 5.0 or 2.0 signal? Confused
I use the Trinnov so I am not fussed.Connect Roon to the Oppo with HDMI.
I am afraid that the Oppo won’t stream multichannel in Roon.
Does it work with Ethernet?and connect my Oppo103 to Roon with HDMI
I use the Trinnov so I am not fussed. [/QUOTE}
I am not surprised
Understood although unfortunate. I keep my NAS drives remote to eliminate their noise from the listening room but I keep my streamers close.The issue with most users is that they have Roon running on a server far away in the house from the Oppo, maybe in a basement, and can’t connect with HDMI. Ethernet is their only choice.
I have used the 7.1 format to give me three subwoofer outputs (5.3 output) and I assume you can do the same with as many channels as you have. JRMC is pretty flexible.Does this work also with other speaker setups such as 7.1 , 7.1.4 etc ?
@Kal Rubinson ?That is what I was planning to do, have a NUC run Roon core and connect to the network with ethernet, then stream to the Oppo 203 also connected to the network, itself connected to the AVR with HDMI... I am unsure now if I will have to connect the NUC directly to the AVR or to the Oppo with HDMI ?
??? I have not tried to connect Roon to the Oppo by network. If I have time this weekend, I'll give it a shot. I can do it with JRMC but that is DLNA while Roon uses its own protocols.
2. David Griesinger mentions in his conclusion "A five channel system is nearly always better than two channel, if the side speakers are independent" What does he mean by independent?
Just coming back to this for a moment, the 2-channel upmixing, that is core to this thread, is NOT 'independent', in the way Griesinger insists is necessary. So... is he right, or is he wrong?Initially, the early 5.1 systems were 4.1 systems were the side/rear channels were fed with a band passed filtered monaural signal. The amp then added some stereophonic noise, a rear dipole created another illusion. I guess that is what David refers to as the need for the side channels to be independent - which they are today.
I tried it and all I get is stereo. Note that the Roon Audio Setting for the Oppo by network does not even have an option for number of channels.??? I have not tried to connect Roon to the Oppo by network. If I have time this weekend, I'll give it a shot. I can do it with JRMC but that is DLNA while Roon uses its own protocols.
