Same bollocks, different name.
I read this via the Node Icon thread.
Most of this could easily have been written about old MQA, and probably was - the triangle is there, the “new information” references papers written by 2010.
It only makes sense if QRONO is a real time, partial MQA encoding that at least keeps the bit where potentially audible data is thrown away, the feature that caught out GoldenSound’s attempt to run standard tests on it. So I would frankly ignore the white paper as a case for or against QRONOS but wait for independent measurements.
Do you mean there is no option to switch to a standard sharp filter? Wow.
It's possible that unlike old MQA, which seemed to pretty much always use the same filter despite the "set" that was provided to it, this time round they might have managed to implement different filters for different inputs. Old MQA was supposed to be able to switch filters in real time via metadata, remember? - but then, nobody ever saw that behaviour in the field, that I remember. So if we're lucky, we may get a sharp filter for standard resolution files anyway.
Old MQA was only an issue with non-MQA files when the company started demanding that their default slow filter was also implemented as the standard filter for all non-MQA files as well, and that did happen on some devices.
I don't think Bluesound is going for bollocks, especially as it can't be switched 'off' in the Node Icon.
Actually it points in the opposite direction. If they were confident of the benefits of QRONO, they'd make it defeatable and let you do the comparison for yourself. If I was trying to sell a new technology under the discredited MQA banner that actually worked, I'd actually go further and build a blind AB preference test into the device.
In fact, you've been around this site long enough to know that audiophiles will believe in and buy any old nonsense that makes some bizarre claim for superiority. If tthey want to claim superiority, they need to prove it. That White Paper falls far short of showing actual audibility.
