This is the central piont in your misunderstanding. Timing !I am simply in favor of progress.
And the time domain is now being addressed and optimised by MQALabs. See also my avatar![]()
Did you read the link about CD systems and timing ?
Can't you answer on your own? Or just use AI or cut and paste from the Stuart and Craven paper like PV is doing if you are unable to use your own words..Then read Peter Veth's comments. Timing is so much more and is now being addressed and optimised by MQALabs/hardware manufacturers.
MQA has the most animosity and I tagged you since your analysis is going to be trusted more than mine or @pogo.
It does more and is easily testable/verifiable.
This suggests that I can take a ADC that has pre ringing and then apply the Inspira plugin which is a transform function to remove the pre-ringing? How does that work with test tones versus actual music?
This suggests that you can test the FOQUS algorithms with any ADC and Inspira is just a PC-based plugin of whatever the new ESS DAC is doing.
It’s the post recording conversion.Figure 1 vs Figure 2 are linear phase vs minimum phase impulse responses, nothing more. I don't understand why the re-invention of minimum phase and noise shaping is worth even discussing or paying for. These were known and used for decades.
Here’s a fair question. Do you hear the difference as they move the setting between -4 to +4?
It’s not the greatest demo since the narrator is talking, but this is again, measurable and testable.
Heck, maybe I should make some
Blind recordings and challenge people to find the flaw in QRONO or determine that there is no difference.
Yes its the optics of seeing the impulse curve with pre ring thats ”unnatural” but it’s hard to understand that this is because of the special test impulse involved which is an instant step afiak . A real sampled and bandwidth limited music signal is never instant it’s always some slope to it ?Figure 1 vs Figure 2 are linear phase vs minimum phase impulse responses, nothing more. I don't understand why the re-invention of minimum phase and noise shaping is worth even discussing or paying for. These were known and used for decades.
A minimum phase filter is not a proper reconstruction filter for DACs since it destroys phase response of the originally sampled waveform. It keeps the frequency response the same, but timing is changed throughout the bandwidth by introducing variable group delay (@NTK mentioned it earlier). Other than eliminating the initial delay that's produced by linear-phase FIR filters (and possibly the simplicity of implementation), there's no real benefit to minimum phase filters in a DAC. They are provably (mathematically) worse reconstruction filters than linear-phase FIR.
The pre-ringing that's touted by audiophiles and MQA/Lenbrook isn't present in a properly band-limited signal. What's more, there's no evidence that pre-ringing (if it is audible at all) sounds worse than post-ringing. Post-ringing in minimum phase results in a time "smear" that's twice as long as the "smear" of a linear-phase filter. All this FUD about pre-ringing is based on visuals of impulse responses of the two types of filters.
Curiously, I just added a feature to DeltaWave to undo the effect of a minimum phase filter in a recording. Should I call this anti-MQA or anti-QRONO?![]()
Isn't this the video where they had to turn off the comments because the pro community reacted so negatively? For technical reasons but also about outrageous cost for a plugin.It’s the post recording conversion.
Yes, see @pkane post above.A real sampled and bandwidth limited music signal is never instant it’s always some slope to it ?
Is it confirmed that Peter Veth is doing this?use AI or cut and paste from the Stuart and Craven paper like PV is doing
No, but if you read the paper (1st reference given in the Foqus white paper) you can see it is just parroting of that. I don't think PV has a technical background but you could ask him how much training he has on the subject of signals and systems.Is it confirmed that Peter Veth is doing this?
What gap in knowledge are you talking about? Can you ever say something specific? I think you don't don't know this stuff well enough to identify another person's gaps in knowledge on the subject. Now prove me wrong if you would like and engage on the points that have been made on this thread. I doubt you will do that.At least he was able to close the gaps in Archimago's knowledge of the new MQA technologies.
I'm learning a lot in the other thread right now. And PV seems to be very well versed in the new technologies, as you can see here, for example: Link
How can you judge his knowledge if you lack the knowledge yourself.I'm learning a lot in the other thread right now. And PV seems to be very well versed in the new technologies, as you can see here, for example: Link
I can't see any signs of this and he seems to know the new procedures very well. I haven't seen this knowledge depth anywhere else. But we can leave it at that at this point. Other sources will certainly shed more light on the new technologies for us in the near future.marketing BS
You're repeating stuff you obviously don't understand. How about we leave that conversation where it is, on the other forum, and you can post your opinions there? You're adding nothing here except for links and quotes to marketing BS posted from the other thread.
