If you are an engineer working in audio for 15 years, I'm surprised you can't grasp what a mockery of science these tests are.
IMHO, if you are planning to test the behavior of something, the first thing you should do is... well, understand what that thing does. Even with a slight, quick sight to the most basic of the dozens of papers or articles about MQA will tell you what this graph shows:
1- that the original noise in the red area below 24Khz is completely replaced with information. If your test is trying to evaluate a bit perfect match with that original noise (that is not there anymore), it is flawed by definition.
2- The quick read will also tell you that the algorithm also requires that red area (now filled with real information brought from ultrasonics) to be dithered, so it could be still read as noise by a non-MQA DAC. And this test omits that critical, basic procedure... as noted in MQA reply, that of course nobody read, or worse, understand. Then... garbage in -> garbage out.
3- That the algorithm is designed to process the signals found in the orange triangle, because that is the space music really occupies, as the red plot shows (before any add more mockery in this subject: this example of maximum amplitudes of a string quartet doesn't differ significantly of any other music, as any Fourier analysis of ANY instrument harmonics would tell you). Then, if your test is full of signals (not music) above that area, both in sonic bandwidth and in ultrasonic region, which is exactly what happens when you use square waves or white noise, either you don't have a clue of what you are measuring, or you did it on purpose to deceive your audience.
4- I could go on and on with several other facts about these "tests", but people here already made their mind. Obviously impervious to any argument.
5- so, if instead of trashing MQA because these "impartial" reviewers told you: "vote with your wallet and cancel your Tidal subscription", we could be arguing why the area above the triangle is not captured by MQA, if because of compatibility issues with Redbook that recovered space can't be used anyway. THEN we would be doing something useful here, and we will be discussing about exactly how that upper side of the triangle is built. Even the same test could have probably discovered it. My hunch: a bezier or b-spline filter allowing antialiasing filters (you would even see the curvature if plotted logarithmically and not flat like in this graph) so as not to smear phases of the signals quantized, which is the whole purpose of MQA. And the filter starting deep in the audible region as to give one or two more octaves for the slope before reaching the displaced Nyquist frecuency, now at 48 or 96 Khz, depending on the sampling, because there was no music to be captured is done this way.
But... it is much more funny to make a scandal of all this, while the scandal are the very tests used here.
A final comment: if you are interested in truth instead of sensationalism, and then find such a degree of anomalities in your experiment, my guess is that any scientist would at least question himself if the experiment is correct or there is something missing. But GoldenEar and Archimago chose the easier path...
And so, here we are: MQA was designed by some of the luminaries of the audio industry. Peter Craven, creator of some of the stones in audio technology that every audio engineer knows, was working in noise shaping, time coherence issues or even lossless algorithms before most people here were even born. And then, all of the sudden, they all forgot a lifetime work and design an algorithm that any engineering student would best in days.... that... or these test were made by amateurs that hardly knew what they were doing.
The amazing thing is that professionals in audio, like Paul Gowan of PS Audio even cite this absurdity to criticize MQA. If I needed one more argument to advise my friends not to buy PS Audio products, this one is it.
