- Joined
- Feb 23, 2016
- Messages
- 20,706
- Likes
- 37,447
The Unpredictable Joys of Analog recording.
http://www.endino.com/graphs/
I am quite shocked by that, didnt expect perfection but.....The Unpredictable Joys of Analog recording.
As I mentioned, you may want to study contemporary mobile bluetooth speakers, especially those made by JBL and Bose. Some of them seemingly violate laws of acoustics, by producing what is perceived as substantial bass, from 2" speakers, and playing that way for hours, using a tiny battery. The first distortion (dropped bone-fide bass frequencies) is perceptually cancelled by another (added higher frequencies not present in the original signal).
So, you disagree with https://en.wikipedia.org/wiki/Distortion?
"Distortion is the alteration of the original shape (or other characteristic) of something. In communications and electronics it means the alteration of the waveform of an information-bearing signal, such as an audio signal representing sound or a video signal representing images, in an electronic device or communication channel."
Perhaps as long as there are believers, customers and the money keeps rolling in it won't be dying until the next best format comes along.
What's it has to do with MQA, and high resolution where you want to sample 0.5uS in several small steps in order to reproduce it more accurately ?
What's it has to do with hi-fi reproducton ?
One can differentiate between linear and non linear distortion. These don't 'cancel out' despite you thinking they can seemingly do... they don't.
It can 'suggest' something. My son has a little toy car that makes sounds (you know, small ceramic buzzer in it) that can seemingly make the sound as if a subwoofer is playing music loudly but consists of pulse trains of a high frequency that appears to make LF sound.
It is fun but don't see this used in any music recording nor any serious equipment intended for serious audio reproduction where higher res audio is used.
This is used for toys (small boomboxes are toys) because the kids like it or it is used for background music.
Serious audio is big boy toys ... there is a difference.
That's why your speakers do so poorly on the Harman tests. Not enough balancing distortion. The missing ingredient to go with the spin o Rama data.Unless I am mistaken, for the levels at which I critically listen, measurable distortions on my main system neatly fall into the range considered inaudible.
Example:
1kHz
View attachment 27848 View attachment 27849
31.5Hz
View attachment 27850 View attachment 27851
I like this example. Illustrates yet another perceptual illusion. Pulse trains of high frequency are also used by class D amps, right? There must be a biological low-pass filter somewhere, for the illusion you demonstrated to work. Perhaps middle ear? Hard to tell without knowing the details of the pulse modulation method used.
Class-D amps for instance have NOTHING to do with tricking the mind. Yes, both are digital. That's the only thing they have in common.
but Class D isnt digital, very analogue
...Tell that to the flash-based, 8 bit CMOS microcontroller (PIC16F690) sitting in every NC-400 module...
Nope.
There is a low pass electrical filter in the amp and of course the speaker is an additional low pass electrical and mechanical filter. What reaches your ear from a class D amp is entirely low frequency analogue.
Mechanical low pass filter would add cost though. More likely, the toy uses the missing fundamental effect, thus employing the "biological low pass filter", creating an illusion of a subwoofer.
