Unless they do a great job remastering the files , nothing.My point was this:
WHAT DOES MQA BRING TO THE TABLE FOR THE CONSUMER (THAT WASN’T ALREADY THERE)?
Streaming of > 16/44.1 kHz through Tidal in US.My point was this:
MQA people did not create demand for high-res. The rest of the industry had done that prior. MQA provides one solution to that problem. Flac distribution is another.I don't think the fact that there is a demand for something indicates anything positive about a product other than perhaps successful marketing. There is still a healthy (groan...) demand for cigarettes despite the fact that they are likely to give you cancer, emphysema etc and kill you. I take my hat off to the MQA people for creating a demand, and for getting the hifi press onboard but as a consumer I still haven't seen any good reason to buy into it.
I secretly hope that he does (become your hero for aformentioned reasons) but suspect he is only after people's money.
If Watchnerd is correct* he may be his hero for that particular album already .
MQA vs FLAC:
100% success rate (so far)
P.S. I take it most have read Archi's response to the video already
Normal people( 99.9% of everyone) just wants convenient streamed audio , they won’t know anything about bit rates etc if you ask them about getting something better they will start talking about TT’s .
We already have that. It's called "as linear as physically possible." Of course, software may be used to compensate for unavoidable errors in the hardware. That does not, however, necessitate a special format. All it requires is that an agreed upon intermediary is used. This intermediary is linear PCM.From a philosophical POV, I do like the *concept* of an ADC (at recording time) and a DAC (at playback time) to be two known, certified entities following a particular standard or method.
No, it shouldn't. That would only exacerbate the phase distortion.it would be cool to know if the ADC used in recording was, say, a minimum phase filter, and thus the playback DAC should be, too,
And potentially hand-tuned new masters created by MQA team. Some of the MQA content I have heard compared to non-MQA sound remarkably better, indicating better mastering.
If you want to undo the phase distortion of a minimum phase filter, you need a filter with the inverse phase response.What filter should be used, instead?
A quick and dirty Audacity frequency spectrum analysis of the first track on the 2L site, "POLARITY - an acoustic jazz project." Spectrum plots taken from 2:30 - 3:30 marks on both files because that's where a lot of action is happening and buffer size limits in Audacity.
...snip...
Unfortunately, I didn't normalize the plots.
But even without that step, there are visible differences, especially in the high end.
Has the MQA one been decoded or is it in the base layer?Blue is the the 192KHz PCM file, red is the MQA encoded one.
2L has the fully encoded file but of course if you don't decode the MQA layer, then you just have the base (in the clear) layer.Base file — at least that’s what I think is posted on the 2L download link.
Some pro cards have loopback capabilities. That would be the best way to captured the decoded MQA so that we don't have to convert to and from analog.Right. That’s what someone would get when playing this on an non-MQA capable DAC. If someone could ADC this file playing through a full MQA-decoding DAC, I could run the same comparison.
