Mozaiklabs TUNE Player (free alternative to Roon)
Please support Tailscale for outside access.
Also ideally a Subsonic bridge, opens up SO many client players!
Symfonium on Android works so well...
It would be nice if library page showed albums both from local drive and favorites from qobuz/tidal etc.
@renesenses, I just deleted everything, installed all again from scratch using the latest build and I can say that it's working perfectly now.
Zones are still baffling for me, but I was able to work around them and get it to do what I need. I have a local zone for my Macmini in my living room and I created a squeezebox zone to my macbook (as i use it to listen while I work there). I can listen and control both without hiccups for now. I was also able to link both my qobuz and spotify accounts succesfully.
And the volume fix is perfect, just what I needed!
I'll be using it more frequently and I'll let you know in a few weeks my longer term review. Thank you for all the help and being available to fix the issues!
Thanks all, this is very helpful.
@aedagnino glad the reinstall went well and that Qobuz, Spotify and the volume fix work for you. Zones are confusing at the moment and we know it: your feedback on what tripped you up would help us simplify them. Looking forward to your review.
@john61ct remote listening already works through a Mozaiklabs account and our relay, with no port to open. Tailscale should work too, by pointing the client at the server's Tailscale address; I have not tested it myself yet, so feedback is welcome. A Subsonic API is a good idea: it would open Tune to Symfonium and many other players. I have added it to our list.
@ObjectiveSubjectivist good point. In the next release (rc9, this Friday), collections already include your Qobuz and TIDAL favourite albums. Showing them directly in the Albums grid next to local albums is the next step.
Bertrand
So for that remote listening feature, how does my TUNE server connect by default to your cloud relay host, tunnel my local audio stream out of the home network securely?
Is that function part of a paid tier?
Can you link to docs explaining these aspects?
Good questions.
How it connects: your Tune server opens an outbound, TLS-encrypted WebSocket to our relay (wss://bridge.mozaiklabs.fr). Nothing listens on your home network and no port needs to be opened on your router. The phone app signs in with the same Mozaiklabs account and connects to the same relay, which forwards the audio stream between the two. The stream is encrypted in transit on both legs. The relay passes it through and does not store it. It is not end-to-end encrypted, so if you prefer to keep everything inside your own network path, a VPN such as Tailscale with the server's Tailscale address is a fine alternative.
Tier: remote listening through the relay is part of Premium. Local use on your network stays free.
Docs: https://mozaiklabs.fr/docs/tune-bridge
Bertrand
@renesenses
Also I'm not sure why but native DSD is not working with ASIO Topping:
Even when I choose Native there is information that native DSD is sent as dop on this output, but why?
ps. not that it is an issue, but just wanted to know
@ObjectiveSubjectivist Thanks for the report. On ASIO, Tune only sends native DSD when the driver reports DSD support for the track's rate when Tune probes it. Otherwise it falls back to DoP, and your screen shows that fallback. We have opened a bug to find out why your Topping driver ends up there, and to show the actual reason on screen. Could you tell us the exact Topping model, your Tune version, and send a bug report (Support menu) right after playing a DSD track? The log records why native DSD was refused.
Bertrand
@renesenses I downloaded and installed the latest Tune server and I have a couple of issues.
First, Tune is unable to send output via ASIO to Acourate Convolver. I get this error message:
FYI these are my settings:
Question: does Tune auto-resample 44.1kHz to the sample rate of the output device? I can't find a setting to force Tune to resample to 48kHz.
If I send Tune's output to JRiver via ASIO, and get JRiver to send it to Acourate Convolver, it works.
There are a couple of other issues with the Android web interface. This is the main one (link to video). As you can see, the songs are listed. But the controls are way off screen to the right. Scroll to the controls, and you can't see the name of the song any more.
Also: your webpage says there is an Android app. Where is it? I can't find it on Google Play.
@Keith_W Thanks for testing again.
1. Acourate Convolver over ASIO: we can't read the error from the screenshot alone. Please send a bug report from Tune right after the failure (Support > Report a bug); it includes what the driver accepted and refused. Most likely the convolver only accepts its own fixed rate, and the ASIO open fails on the first track at another rate. The report will tell.
2. Resampling: Tune does not resample by default. It sends each track at its own rate (bit-perfect), and only resamples when the output refuses that rate. There is no option yet to force every track to 48 kHz. The existing "maximum sample rate" setting only converts within the same family (44.1 stays 44.1, 48 stays 48). Forcing a fixed output rate for a convolver like Acourate is a fair request; I've noted it.
3. Android browser: confirmed as a bug, the playback controls overflow to the right on a phone-width screen. It's tracked here: https://github.com/renesenses/tune-web-client/issues/2e phone model and browser, it will help.
4. Android app: Tune Remote for Android isn't on Google Play yet. It's distributed through Firebase App Distribution for now: https://appdistribution.firebase.dev/i/f544e28934b0c02
Bertrand
@renesenses thank you. I have entered the details you requested into your bug tracker. I will send you a bug report from the app. As for your Firebase app distribution, the link is broken:
@Keith_W Thanks for the details. One more question to be sure we fix the right thing: do you have the VU meters enabled in the player bar (Settings, VU meters in the playback bar)? With them on, a tablet in landscape is exactly where the controls overflow; that's fixed for the next release (rc10, Monday).
Bertrand
If I had a Eversolo DMP-A8 and play a lot of DSD would DLNA or Squeezelite via Tune give me best results to maintain volume control
@renesenses
Is there any plans for more Roon like Features - Thing that keeps me there is Versions some albums I have 5 versions but some are same sample rate just different origins ( tape,vinyl,SACD,cd) and versions is super nice
Otherwise in my testing if I run Tune in Docker will my Dac on my windows PC appear as a zone or do I also need to install tune server on windows?
Love the project is there a native app for windows or just browser
Cheers
K
@globadyne thanks, glad you like it!
DSD to the Eversolo DMP-A8: use DLNA/UPnP. The A8 is a UPnP renderer, Tune sends DSF as is (no conversion to PCM) and the volume is driven through the renderer's own volume control, so you keep it in Tune and in the app. One known limit today: gapless between two DSD tracks on DLNA is disabled (a short gap between tracks), it is on our list. Squeezelite is fine for PCM, but for DSD with this device DLNA is the simpler path.
Multiple versions of the same album (remasters, hi-res vs CD, etc.): not yet grouped like Roon does, each version shows as its own album. Noted as a request.
Docker on Windows: no. Docker Desktop runs Linux in a virtual machine, so the container cannot see your Windows DAC (no WASAPI or ASIO inside it). Docker is fine if all your zones are network devices (DLNA, Squeezebox, AirPlay...). For a DAC plugged into the Windows PC, install the native Windows version of the server: the DAC then shows up as a local zone, with WASAPI exclusive or ASIO.
Native Windows app: the server runs natively on Windows (installer on the download page). The interface is the web client, opened in a browser on any device of your network, plus the iOS and Android remotes. There is no separate Windows desktop interface.
Thanks for detailed response
So if I move my server to docker on my main server with my data I just also run an instance of tune server on windows and lend its outputs ?
I assume Tune OS has the same limits
@globadyne yes, that works. Run the server in Docker on your main server with your library, and install the native Windows server on the PC where the DAC is plugged in. On the Windows instance, open Settings > Devices > per-zone settings and tick "Publish this zone on the network" on the DAC's zone. The Docker server then sees that zone as a network renderer and can play to it. The Windows instance needs no library, it only acts as an output. I would still test it with a few of your DSD files.
Tune OS does not have this limit. It runs directly on its own machine (a Raspberry Pi or a small PC), not in a virtual machine, so a DAC plugged into that machine by USB shows up as a local zone, bit-perfect, with native DSD or DoP depending on what the DAC supports. The limit only applies to a DAC plugged into another computer: there you use the same approach, a Tune instance on that computer publishing its zone, or a network renderer.
I was testing windows only and DSD played perfect , Lyrion couldn’t even do that when playing to a Windows Zone.
Hopefully gapless is a feature that can be fixed then other than versions I can make the swap
Please leverage the MB frames MUSICBRAINZ_RELEASEGROUPID vs. MUSICBRAINZ_ALBUMID
and/or DISAMBIGUATION comments
rather than just Roon's proprietary VERSION
Thanks john61ct, agreed, and that's the plan. Tune already reads MUSICBRAINZ_RELEASEGROUPID and stores it per album (we use it today for duplicate detection), so grouping will key on the release group first, then fall back to a normalized artist + title match for untagged files. DISAMBIGUATION comments and the VERSION tag will label each version inside the group rather than drive the grouping. You'll get one entry per work with a version picker (year, label, format, resolution) and a preferred version. Scheduled for the next release candidate.
