ASIO driver is Topping ASIO 6.16.0
Version of tune is v1.0.0-rc7
"- what you see in Settings › Zones: does the device show up at all, and does it say anything when you try to use it?"
TBH IU have no idea I select checkbox nearby ASIO device but how to choose it? There are just some devices (zones?) visible but I cannot select Topping asio.
Selecting deselecting devices makes pretty much nothing, nothing is changing, also all my network devices disappeared from Audio settings but I can select them in zones (?)
Why there are 3 zones that are basically routing audio to my computer? (this computer, this browser, this browser)
"The quickest way is the bug report button in Tune (Settings › Support › Send a report): it sends the logs we need. And point taken on the zones setup feeling unintuitive. Where exactly did you get stuck?"
The whole audio/zones/devices thing is just too much. Why it has to be spited into 3 sections? Just pack everything into devices tab and let me setup everything there.
Roon approach is much more intuitive, just select which devices you want to have listen on main screen to control - then you can switch between them - which is a zone.
Oh I just figured it out that I can create new zone and select topping asio when I enter zones on the left
But I cannot create new zone and select topping asio when I enter zones through settings - that's why I was confused. Now it's a bit more clear.
Anyway as I said whole spliting devices into 3 screens - and now more like a 4 is not really good in my opinion.
ps. I'm keeping my fingers crossed for the whole project, had not time in the past couple days but I'll try to use it daily from now on and see how it goes. Will report any problems through "Support report a bug" page
