Mozaiklabs TUNE Player (free alternative to Roon)
Seems nice software.
I use Music Assistant (I need Apple Music integration), is free and local and does everything for me, here AI pros and cons:
The Good (Pros)
  • Unified Library: Seamlessly merges local music files (from a NAS, SMB share, Plex, or Jellyfin) with cloud streaming services (like Apple Music, Spotify, and Tidal) into one single interface.
  • Cross-Brand Multiroom Audio: Groups and syncs disparate speaker brands and protocols—such as AirPlay, Google Cast, DLNA, and Sonos—into synchronized zones.
  • Advanced Playback Features: Adds features like crossfade and volume normalization, parametric EQ, even to hardware that doesn't natively support them.
  • Home Assistant Integration: Allows you to build custom dashboard controls and trigger complex audio automations (like playing a welcome track or adjusting volume by time of day). my favorite one!
  • Revives Older Hardware: Breathes new life into legacy network players and speakers that no longer receive official software updates or modern streaming app support.
The Bad (Cons)
  • Requires Home Assistant: It is not a standalone music server application; it relies entirely on a running Home Assistant environment to function.
  • Steeper Learning Curve: Setting up multiple streaming accounts, mapping local storage shares, and getting different casting protocols to behave smoothly requires patience and troubleshooting.
  • Dependent on Third-Party APIs: Changes or restrictions introduced by commercial streaming platforms (like Spotify or Apple Music) can occasionally break or limit integration features.
  • Hardware/Network Sensitivity: Synchronized multi-room playback heavily depends on your local Wi-Fi and network stability; weak signals can result in audio drops or sync drift.
I was quite interested until "Requires Home Assistant". That is clunky garbage! "Open the pod bay doors, Hal" "I'm sorry Dave, but I'm busy doing crochet".
It does not require Home Assistant. You can use Home Assistant if you want. That guy's response was AI garbage.
Trying out Tune Server and their web UI. Not sure how to test the iOS app, is it only available via TestFlight currently?
Cool, but i'm having some problems with setup - with asio drivers and overall zones/devices and how it is managed.
Don't have much time today will try in the couple of the next days.
But i'm keeping my fingers crossed
I have been using for a few days now. It works, and for my usage it may as well end up replacing Roon, as I cannot justify the price for my modest needs (small library, two zones).
The overall experience is naturally not as polished as in Roon (first Roon setup took a few minutes and no tinkering needed afterwards), there are quite a few bugs that may annoy one expecting a ready alternative, but progress seems to be fast.
Can I install the app on an iPad or iPhone and use it directly to stream Qobuz library to a DLNA renderer, or is a separate server required?
Not sure about iPad, but I have it installed on my iPhone via TestFlight, playing to my WiiM Mini through UPnP. Works great, except for the ridiculous round album covers.
Read the first post carefully, there is no app. It's a web app. So you point your web browser at an IP and you control it that way.
I’ve tried running it via TestFlight but the screen asked me for a server address. So, it’s pretty clear that the iPhone serves only as a remote client. I would need a server up and running, which isn’t the case. I only need access to the Qobuz library.
@Ralph_Cramden You do have a server running on your PC, right? Thanks!
There is an app, but it's currently available via TestFlight for iPhone.
Yes, I’m running the server on a Mac Mini. While you can point your iPhone browser at the server, it renders poorly that way. The desktop browser renders nicely.
Yes, app is free I know. But when I open app, it asks Invitation code. When I asked this code from Mozaiklabs, they sent me a link to Apple Developer page, where in the end of registration they ask money. Otherwise enrollment will be cancelled.
Or you can BYO DSP engine (e.g. Hang Loose Convolver or Acourate Convolver). Maybe even EQAPO.
How might one do that if the plugin framework doesn't support standard VST? One of the bullets stated plugins were in a proprietary format.
Am I missing something?
You pass the output from Tune into whatever convolution engine you like. The only engine it won't work with are VST based ones, e.g. Dirac.
Oh, maybe you already pass that ip address stage.
