In the meantime, a few things have changed for me.
Up until now, I’ve been very satisfied with the sound quality and soundstage of my KEF coaxial speakers (R5 Meta).
Here and there, though, I’ve noticed that the sweet spot does indeed disappear when I move my head slightly.
Perhaps this could have been adjusted with a different setup (by toe in or out), or maybe it’s just a characteristic of coaxial speakers.
But I’d also read a lot about Ascilab speakers (F6B / C6B) and, for testing purposes (due to lack of availability), I ordered the F6B, even though I actually preferred the C6B.
The sound of the F6B was very good, in my opinion—something I hadn’t expected.
This led me to reconfigure the system once again.
The F6Bs were mounted on brackets on the wall, where they’re fairly securely installed.
If kids ever come over, you can secure the speakers a bit with a strap so no one can rip them off.
I then calibrated them with Dirac Live Bass Control, and I have to say the sound is very good in my opinion—it really speaks to me much better than the KEF R5 Meta did.
They’ve been sitting in the next room ever since, out of commission
Ascilab did a very good job here.
The Nubert XW800 Subwoofer is still in use and on the same place, cause the place is very good.
I’m just wondering now whether it makes sense to switch to the C6B or if, in terms of sound quality, it won’t necessarily make much of a difference.
Looking at the Spinorama data, the F6B and C6B are actually quite similar in terms of measurements and directivity.
Has anyone compared the F6B and C6B in the same room and can help me decide?
I'm currently undecided about whether the extra cost for the C6B is worth it, since the only differences between the F6B and C6B are the drivers and a slightly different crossover, as far as I know.
Here are a few screenshots of measurements with Dirac Live Bass Control enabled.
The Crossover is set to 80Hz in DLBC.
Linear flat target curve measured at the listening position:
Here are the RT60 data for this measurement as well:
And then, using MMM measurements, I was able to get close enough that by adjusting the Dirac target curve, I achieved a reasonably balanced curve at my listening position.
Here is the MMM measurement of my current favorite target curve:
